Tapage:
Can you post pics of your engine with BOV?
I have a 13B-T, does it have a butterfly?
cabadian bum:
Someone told me that I should catch the blow-by as the oil from blow-by hurts performance. As per the adviser; the oil reduces the combustion/diesel-oxygen capacity thus reducing performance.
In my case, yes the intake is full of oil.
Tapage:
I am going to get the boost controller anytime soon now. Had a question; How do you adjust the PSI? I mean how can I exactly set it to 14.5PSI? I am asuming that I drive it and callibrate the boost controller accordingly but that will take time. Is there any easy way?
Oil can be a big problem in petrol engines as it drops the octane rating of the fuel, but not so much in diesels. In diesels it is fuel.
Diesels with piston squirters have much bigger problems with oil in the blowby than those without. Many have an air/oil seperator in the blowby tube before it exits the rocker cover (or wherever else it exits).
As heavy duty diesel mechanic most all diesels have piston squirters but this does not increase the amount of oil that will come out of the blow by tube. The tube itself is just a vent with little to no pressure escaping while running there maybe a little oil vapour but that is all. When it starts to shoot lots of oil out there is problems with the cumbustion pressure escaping into the crankcase.
You don't need an intercooler it run 14.5 PSI. It cools the air that is going into the engine making it more dense meaning more air is going into the cylinder and therefore meaning you can put more fuel in and more power. However this may raise EGT's and increases the cumbustion pressure and your already reaching the overboost of 15 PSI. If your building yourself a race car you can look at water meth injection to cool the temp of the exhaust or propane injection. Water meth is actually pretty simple.
