What parts do you recommend replacing on a 260K miles 100 series? (4 Viewers)
USA
After purchasing my 100 series last year I spent over $5K base lining it at Land Cruiser Heaven.
Fluids, new brakes, new timing belt/water pump etc.
What other age or mileage parts should I get ahead of?
Bushings? But honestly, unless you are somewhere super dry and hot, those may not even need changed. Those usually are worn more by location conditions and use case scenario, as opposed to strictly age/mileage.
Land Cruiser's are simply amazing. Mine has been sitting for years (5-ish). I have no free time to drive it like I used to and it needs the timing belt / water pump replacement, that I have parts for.
Last Saturday, because my pickup was getting service, I started it, noticed the fuel level was 1/4 tank. drove it to town, did some business, then drove home. 249,000 on the clock if I remember right. All in all I may have driven 15 miles that day. The gas was the same stuff that was in it when I parked it. On the way home I got a warning light and the engine was running a bit rough, and I blame the fuel. I'll take it in tomorrow and fuel it up.
I keep a battery tender on it but it died and I had to replace the batteries. It's a just a beast of an automobile...
Fluids, brakes, and timing belt / water pump / coolant are the big ones, and you got em' all done + brakes, that's a big win... I say go out there and enjoy it....
Assuming all fluids covers front and rear differential, transfer case, transmission, coolant, oil....If you want a few more easy / cheap things to DIY you could, replace air filter, clean MAF sensor, make sure battery cables are tight and clean, check ground cables
what type of driving are you doing? do you find yourself hours away from service and in remote areas, or do you stay within range of civilization ? If you venture out far and need 100% reliability, or if you're just bored and want to start replacing stuff, then you could throw some money at parts like spark plugs, coils, fuel pump....You can go down a rabbit hole quick and if you don't do your own repairs it gets expensive. I've dumped at least $15k over 7ish years into my 100 series on stuff that was never like really broken lol
After heater tees, fluids, brakes and timing belt, I’d start this list:
  • Repack front wheel bearings
  • Snake sunroof drains
  • Clean Mass airflow sensor
  • Clean throttle body
  • Cabin Air Filter
    • OEM: 8856860010 (2 required)
  • Fuel filter
  • OEM: 23300-50090
  • New PCV Valve ($15)
    • Redesigned mid cycle.
    • Pre 2003: PCV Valve 12204-50020 with Grommet 90480-18001
    • 2003+ PCV Valve: 1220450030
  • New spark plugs
  • 9008091180 (8 required)
  • Re-boot coils
  • Denso ignition coil kit 671-8184
  • Leatherique on leather
Cheers
I travel 500 miles each way once a month for work.
3 years ago someone attempted to car jack me on this stretch of highway.
I want everything as reliable as possible for this trip.
Yes I have a pew pew but don’t want to get in a situation to use it.
Big things that typically need replacing after 20 years:
Bushings in all suspension parts
Steering rack
Brake booster
Charcoal canister
Valve cover gaskets
CV Axleshafts, especially outer stubs
Don't replace if they don't need it but these things may need it in the next 5 years.
Edit to add: some of these parts are being discontinued by Toyota, so if you don't get them, may be forced to buy aftermarket or rebuild.
How crazy do you want to get replacing things that don't need to be replaced? Take it back to the same Land Cruiser shop that did your baseline and pay for an hour of labor for them to inspect it. Replace what fails their inspection.
  • Cabin Air Filter
  • Fuel filter
  • OEM: 23300-50090
  • New spark plugs
  • Re-boot coils
Cheers
Thank you! We’re on the same page as I’ve already done most of this list
I’m trying to get ahead of the curve. In my other hobby (vintage VW’s) I replace fuel lines every 2 years, regardless of miles to help prevent fires.
What parts are time or miles?
I paid LCH for a full inspection. They found stuff I didn’t know about and most of the list is checked off
Refresh entire cooling system. Radiator, all of the water hoses + clamps (including coolant reservoir hoses), heater tees, fan clutch. Then do all of the vacuum hoses, PCV valve, fuel vapor hose. CV axle re boot. Serpentine belt idler + tensioner. Door weatherstripping, reseal / replace 3rd brake light (water leaks into trunk). These are just some of the things I've done over the years - around 150k miles.
I remember putting fires off Aircooled VWs many times, most were caused by ppl that added a cheap fuel filter before the carb and too close to the manifolds, but if a quality hose was used and a good filter was installed after the fuel tank, and NOT in the engine compartment, it can last several years, depending on climate.
Same with 100 series rubber, I'm about to replace the front lower control arms with new #2 bushings (waiting for the heat to calm down a bit), but after replacing several rubber bushings, most were OK to keep going for a while longer. 20 years of service, amazing. Can a Ford owner say the same?
New OEM bushings aren't cheap, and the labor to replace can be intensive, but it does smooth the ride and feel, like replacing old tires with quality new ones, but after a week it feels normal again, and you want to keep replacing stuff to get that effect again.. addictive.
All opinions are valid here, but the things that can leave you stranded are very few, and common on any car regardless of the year or brand. Alternator, starter, battery, cooling system leading to overheat, it can happen on a new car too.
Edited to ask, and completely off topic.
Would you mind sharing the hijack experience? I’m always fascinated by these stories, sorry that happened to you and I’d like to hear it.
Fan Bracket - I bought a non-running 2UZ with 260,000+ where the fan bracket bearing shot ball bearings into the timing belt and caused it to jump.
  • Back
