What is your FJ40 Restoration Shop Garage Set-up?
Well here in the north we have radiant heat on top of 4” of foam, another 4” x 2’ deep around the perimeter, r22 overhead door, R26 walls and R50 ceiling. Just sayin
Guess if your a business or have unlimited garage space it's not a problem. The garage in the pictures is also the parking for our DD. Those are garaged every night. Have tools and materials for home projects mixed in there. Power use to be spotty in the area so have a couple of generators as well. Just moving between the 40s is hard enough much less working on them.
What I have noticed many of these shops are not insulated. Are these in warm climates or have a heating source that coat doesn't matter. While this is in Arizona it does gets cold. April 15th and this mornings low was 22°. I have a thermometer that records the high and low temperature. I have never recorded a temperature below the mid thirties.
My garage is only insulated on the 2 walls that adjoin the house, and it has a 12 foot ceiling. I’m in MD. When I was rebuilding my transfer case last winter I remember having to break through the ice in my bucket of soapy water cleaning parts, then hold my hands in front of a space heater to thaw them. Had to bring the case inside and let it sit at room temperature for a day before I put gasket sealer on it as I was afraid it wouldn’t cure properly.
Trying to figure out the best interior flow, electrical runs, lighting, and insulation.
30 x 48 x 15
My last metal shop building had rolled fiberglass batting insulation. The only thing I didn't like about it was that water condensed in that shop. So on my latest one, I had an inch or two of spray foam put on everything - walls, ceiling, inside of the bay doors, etc. I like that a lot better; now I don't get water condensed from the air. The insulation helps in both summer and winter here in north Texas. I don't have any air conditioning in the shop, but if you open the windows and bay doors you get a good cross circulation and a fan blowing on/near me is usually all I need in the summer. Our winters are about like yours; freezes 10-12 times per year but usually not less than 20 F. A small propane radiant heater will heat up the work space reasonably well in the winter. I usually only use it a few days per year.
You guys are killing me with these awesome garages, shops, etc. I have a 1600 square foot space under my house. We are on pilings because we live on a barrier island so I cant improve the space too much. This space was under 10 feet of water in 2004 as a result of hurricane ivan. But the space is nice.
Here is mine I'll get a better pic ltr. In the process of building a full length bench to tuck welders out of the way and have more junk collection area on top...
@Purpleaction Off topic, but I thought I recognized the 40 in your pic. I saw you drive by when I was in Pensacola last month...
Back on topic... I am envious of the nice workshops. I work on my 40 in a two car garage that is imploding with crap. I rebuilt my '82 40 in the garage 17 years ago but there is no way I could do that now... My garage is also doubling as my office while on lockdown... Here is a recent photo putting in a rear ARB and CV's in my sons 4Runner.
45 restoration shop and camper storage
The steel table (on wheels now) is my most important shop element. I can move it around, inside or outside, do layouts, and weld on it. It weighs a ton. Aprons are my principal work space when weather is good.
Our last place (before this one) was the first time I had a dedicated shop building; it was already there when we bought that place. My wife says we only bought that house and land because of the shop! Maybe close to the truth; it was a big draw for me. It also had an office built in to one corner, which was perfect for me since I am self-employed and work from home, so my other justification.
I put a hoist system in it for my hard top:
I would love to see more photos of the hoist. Having not taken my top of yet recent purchase, what’s involved in taking it off in 1 piece and is it ok for the cruiser too?
@Otis....irony in that you we’re visiting from Cali to Pcola and saw my Cali spec 40 in Pcola. It spent most of its 42 years in California.
@Otis, are you by chance a geologist? Looks like a surface geology map on the monitor in your photo.
Yes... I work mostly on studies for large civil engineering and infrastructure projects. It seems like many geologists I know own Land Cruisers...
I'm enjoying looking at all the stuff in the background of these photos. Things on the walls, bikes, bicycles, tools everywhere. Lots of normalcy mixed in with the restoration madness. Ed
There are more photos on an old thread (about hard top storage) here in the 40 forum, I will see if I can dig it up.
Edited: @Crush 4 , here you go - I used the exact Racor hoist from Amazon as in this thread, there are several examples:
Hard Top Lift
The tops are meant to come off; until I moved, I took mine off every spring and put it back on every fall. You have remove the 10mm bolts through the top into the windshield frame, the bolts from the top to the top corner of the door frame, the pinch bolts in the tub for the B-pillar posts on the bottom of the hard top, and all the 10mm bolts that go through the bottom of the hard top sides, into the top of the tub. Depending on the year you have, you may have to disconnect the interior light wire at the top left corner of the windshield, and remove the ambulance doors if you have them. Pay attention to all the rubber weatherstripping and gaskets that come off, so you know where to put them when it goes back on.
If you don't have a hoist for it, two people can lift the top off. Three or four would make it easier.
I am also; primarily oil & gas but I have also done some surface mapping and ground water work for clients.
