Will do, should I use up my spares or do you have a trade in program.
depends on how much you enjoy pulling your steering knuckles off on the trail?
Are the Chromo Hub gears the ones that Longfield also sells??? Also, which ones, the IFS or Solid hub? The front axle is stock, so do I have IFS or Solid gears
WARN hubs, from an FJ40 with disc brakes.
yesAre the Ansin hubs better/stronger than the Warns?
yes, however, when used with stock 40 birfs there can be stipulations based on year of truckWill Ansin hubs from a solid axle mini truck bolt on a 40?
yes, once the gear is replacedhow about a independent mini truck hub?
WIll 84-85 Mini truck hubs bolt on a 78 FJ40 without any mods.?
Can I keep the WARN hubs on and run the long 30 splines.??????????
