What is a Birfield??? (2 Viewers)
:cheers: Will do, should I use up my spares or do you have a trade in program. :D
depends on how much you enjoy pulling your steering knuckles off on the trail?
Are the Chromo Hub gears the ones that Longfield also sells??? Also, which ones, the IFS or Solid hub? The front axle is stock, so do I have IFS or Solid gears
Are the Aisin OEM lockouts you are getting, coming off a solid axle truck or one that has Independent Front Suspension?
WARN hubs, from an FJ40 with disc brakes.
You are aware that you will need to get different lock out assemblies, correct?
Long gears do not work in the Warn lockout...
Are the Ansin hubs better/stronger than the Warns?
Will Ansin hubs from a solid axle mini truck bolt on a 40? how about a independent mini truck hub?
WIll 84-85 Mini truck hubs bolt on a 78 FJ40 without any mods.?
Can I keep the WARN hubs on and run the long 30 splines.??????????
Sure, and then when the lockout goes boom and ruins the splines on the outer axle stub (birfield) you will be purchasing another one...'cause that is not a 'warranty' issue....as you have been told how to do things correctly, both here and on the Long site...
:meh:
Thanks
As a newbie... I have learned a ton from you guys. Thanks for helping a rookie out. :)
