What have you done to your 200 Series this week? (25 Viewers)
Any chance you remember where you got the third row seat covers from?
MF34Inc would know for sure, but I believe the seat covers are these:
to be honest - it was not last week ;-)
Looks very sharp. Does the paint has ceramic coating?
Thank you! No, I use Jescar Powerlock paint sealant topped with Collinite 845 wax, then I’ll use P&S Beadmaker with every wash to maintain it. I prefer this to a ceramic coating because if I get any pinstripe scratches while off road, I can remove the wax and do a paint correction then reapply with no issue. I got this method from Obsessed Garage. If you haven’t checked it out, I highly recommend.
Thank you for explaining. I am going to try this :)
Just picked up my Dobinson's Drawers from the frieght terminal. Who wants to help me install them? The box is only 235lbs so they should be easy to wrangle.
Edit: what do you do when that box gets wedged between the wheel wells and won’t budge? You use a pry bar to lift it just enough to get a tow strap on it and then just pretend you are pulling a bus in the Worlds Strongest Man Competition.
[not bling] Just cleaned the windshield inside and out - and replaced the garbage after market wiper blades with OEM all around. [/not bling]
OEM are definitely a quality product.
Also have the hvac blower fan now on the shelf. Will work that in soon. 164k now, heard the squeal last weekend for a bit sitting idle in the ski hill parking lot.
I had to remove the front mud flap, push the fender liner forward, and remove the rubber flap that hangs down by the tire. Nothing hard and only took about 10min.
It certainly looks good
You can make a cellphone slot in the dual version by taking a Dremel or similar tool and removing the material in the middle, between the two pen slots. This is assuming your phone isn’t in a “fat” case. I did it with the two small inserts but no reason why it could not be done in the full replacement version as well. Just verify that your phone will fit before going hog wild.
