What have you done to your 200 Series this week? (15 Viewers)
Ok, so here is the best I could do for you. I live in the city, so this was the darkest place I could find within about a mile from my house. The woodline is about 150-175 yards away.
Without any lights:
With my LED driving lights:
With my LED high beams:
With the new LED Spotlights:
They are very bright. Now, that being said, they are still LED and will not have as much throw as some high-power halogens.
And just for fun, this is what it looks like from about 25 yards away. My neighbor texted me and asked me if a UFO had landed in my garage. Haha.
Thanks MSCruiser ! Super looking lights. Like the reach and they sure look blinding. Added to the purchase list [emoji1]
Sent from my Nexus 5
I bought the 185w pair of those same lights. I couldn't see the point of going higher wattage than a set of halogens. They are awesome bright, but as always with LED, you lose a little distance compared to the HID's I replaced. I'll end up putting one of my HID's in between them shortly to be able to scan along the edges of the road a bit better. The spread lense cover throws light out at better than 60deg either side of centre.
I've been giving mine a caning in 40deg C days & mid 30's at night for hours at a time as both worklights and driving lights - so far I can't fault them!
Installed a different awning. Will move the shady-boy to above the rear hatch (it's intended purpose, so as not to foul the hatch) and put the Howling Moon alu-awn 2.5 over the passenger side. Huge screen windows and great quality materials at first blush. I'm sure it will hold up great based on the SA forum reports. Using snowpeak stakes instead of the wimpy ones it came with though.
Is that an Autohome tent? I am looking to purchase one of these.
Hello, it's a James Baroud model Grand Raid XXL which we preferred to Autohome/Magiolina. I think it just comes down to minute preference between these two but we are exceptionally happy with the Baroud. It camps even better than I expected, personally. Weather seems to have little effect and it's hard to remember the reality of the outside weather sometimes..until you unzip.
The Grand Raid is absolutely huge inside for a hard shell, if that's what you're looking for. On the 200 we weren't so concerned with size or weight.
Thanks!
I am having trouble finding a roof rack for my roof top tent. I have an Autohome Columbus, medium. The rack for me has got to be wide enough to support the tent. The tent has to be mounted high enough above the vehicle to get your hand and a tool under the tent to secure the tent to the rack. Thule feet working with factory rails, I am concerned don't create the clearance needed. Tray/flat type racks are not wide enough. Not being wide enough, I believe, will create stress fractures where the tent overlaps the tray/flat rack. I have looked at Thule, Rhino Rack, Front Runner and the Gobi racks. I am just not happy with the choices that are out there. Does anyone have an Autohome Columbus or James Baroud "clam shell" type tent mounted to a rack on a 200 that truly supports the tent's width? Ideally I'd like to use bars mounted to rain gutters like on an 80 series but that not happening on the 200.
Our Eezi-Awn 2.2m platform rack comfortably supports the width even of the Baroud XXL, the rack is 55" and the tent is 64" so it reads as 4.5" per side but the base footprint is actually within the confines of the rack walls. It's one of the primary reasons we chose this rack. I have it deliberately overhanging the driver side by a number of inches without any concern. I don't think there is a wider hardshell tent out there than the GR XXL(?) and it's comfortably supported in both width and length. If you choose this rack make sure to ask your tent manufacturer for 3"+ mounting brackets as the cross bars are wide and stout (came with 2" ish?).
Eezi-Awn K9 2.2 Meter Roof Rack System for Toyota Land Cruiser 200 Series
Rhino rack has come out with a track system for the 200. Now up to 4 bars can be placed any where along the track on the roof. This is the solution I'll be going with. The fox wing can also be mounted to the bars.
Without any lights:
I tried out the LEDs for the low beams.
Since I had already upgraded to 4300K HIDs I found the LED light whiter but not brighter. I installed them on a friends truck who had halogens. He loves them.
The great thing about he LEDs is you can use them in the lows, highs and fogs for a uniform look. You can't use HIDs in the highs or fogs because they take about 10 seconds to warm up to full brightness. You wouldn't be able to switch between low and highs.
Thanks for the review on the GIANT driving lights. Those must be awesome.
Slee MAIN battery tray joins Slee 2nd Battery Tray... Now just need dual battery wiring, etc.
The MAIN tray from Slee is incredibly secure...even though I opted NOT to bolt it from underneath. I'm convinced it's more secure than stock even with my minor work-around in avoiding removal of the wheel-well skirt pieces. I'll describe that if you're curious. Here it is installed... Obviously no dual wiring yet...
The MAIN tray from Slee is secure...even though I opted NOT to bolt it from underneath. I'm convinced it's more secure than stock even with my minor work-around in avoiding removal of the wheel-well skirt pieces. I'll describe that if you're curious. Here it is installed... Obviously no dual wiring yet...
I would like to hear how you installed with out bolting from underneath and what your thoughts are on its security... I am pulling the trigger soon on the two trays.. What dual battery isolator are you going with?
About NOT bolting from under the tray:
(OK...Long explanation over a battery tray...but if you're interested...here ya go)
First... This is my doing, and not Following instructions indicating securing bolts from underneath--which would certainly add a Superman-Level of solidity. Anyone who knows Slee stuff knows he goes above and beyond in terms of strength, and this is no exception. Another awesome product!
That said, I'm not even slightly worried that it could move. I did use the bolts...but only to stop lateral movement....not to hold it down. The top bracket pressure does more than enough for that. It's still FAR more "attached" and secure than the stock tray from Toyota, which is literally a flimsy, unattached plastic rectangle without any bolts or screws.
Main reason I did it without the nuts on the back side under bolts... It's a real pain to remove the skirting that lines the wheel well without breaking the small, plastic tabs/attachments. I tried...but didn't want to end up with dangling skirt pieces (didn't have any plastic clip replacements)
Toyota's battery tray convinced me it was OK, as the Toyota stock tray is a wet noodle...
-The stock Toyota battery tray is just a thin, flimsy plastic...and there are NO screws or bolts at all!
-All the Toyota tray has to keep it in play from below is a round protrusion in the plastic bottom of the tray that's about an inch across. This protrusion simply juts downward maybe a quarter of an inch into a hole in the sheet metal below it so that it can't slide sideways. Beyond that, the ONLY thing holding the battery in place it the standard top bracket and tie-down screw.
On the Slee tray setup...the tray itself is heavy steel, and FAR more rigid/robust than stock.
-Not only is it very rigid, but the edge which holds the battery within the tray is FAR more robust.
-The Slee top bracket that holds the battery down is HUGE and locked the battery from forward or backward movement.
So here's what I did...
-I did drill the additional hole below the tray (see instructions from Slee)...before I realized what a pain it seemed to remove the skirting.
-Instead of bolting the tray, I simply inserted two of the bolts through the tray and through the holes beneath the tray. These bolts cannot come out because the battery rests directly above them.
-All the bolts need to do is prevent lateral movement like the plastic circle protrusion did on the Toyota tray...and the bolts do this far better than the plastic circle.
-Once the top bracket is tightened downward over the battery, there is absolutely no way that tray is going to move.
I pushed as HARD as I could in every direction, and it was absolutely solid as a rock.
My conclusion:
-It's FAR more solid than the tray that comes stock...even without bolting from the bottom. No comparison. Absolutely motionless.
-The tray, top plate and connectors are top notch and do not budge at all.
-When I eventually replace the bumper, or have a need to remove the wheel-well skirt...I'll attach the nuts to the tray bolts from underneath...but meanwhile...there is no way that tray or battery is going to move.
First... This is my idea...and not following the Slee instruction--which would certainly add a Superman-Level of solidity. That said, I'm not even slightly worried that it could move. It's FAR more "attached" and secure than the stock tray, which is literally a flimsy, unattached plastic rectangle without any bolts or screws.
Why no bolts? Main reason...it's a real pain to remove the skirting that lines the wheel well without breaking the small, plastic tabs/attachments. I tried.
Upon inspecting the stock Toyota battery tray...
-The Toyota battery tray is a thin, flimsy plastic...and there are NO screws or bolts at all!
My conclusion:
-When I eventually replace the bumper, or have a need to remove the wheel-well skirt...I can always attach the nuts to the tray bolts from underneath...but meanwhile...there is no way that tray is going to move.
Thank you for the detailed explanation...
Keefer
Huge battery and looks great! Definitely on my short list of mods. I do cringe seeing the exposed positive terminal, but I'm sure there are generic covers available.
I'm gonna just slice a short piece of a radiator hose & stretch it over the positive terminal area. Seems like it would make a decent cover that would be easy to quickly cut when more wires come in from the side for winch, etc...
Haha my posi is exposed as well, keeps you on your toes when you work on your rig
Ya, my 100 had exposed positive for the 13 years I had it... :meh:
OK... Here's my Super Duper High-Tech pos. Terminal Cover for the longer terminal on the Slee tray... About $1...
Zip-tied a loop to keep it out of the fan if it ever came loose... Fancy shmancy... :hillbilly:
Ya... I know it ain't as perty...
  • Back
