I did the same thing too, kind of. It worked great and never had any issues. The hardest part was drilling into the dash.As I’m trying to adapt to life in a 200, I found myself missing the coin pocket to ram mount conversion that I did in my 100. First world problems for sure. It took a bit of bravery on my part as a replacement bezel assembly wouldn’t be cheap if this doesn’t work out.
I removed the shifter bezel and center console assembly and drilled some holes. The forward hole lines up with an existing screw so that one was easy. Remove the self tapping screw and drill completely through the assembly. Lined up the second hole using the ram mount and found an acceptable spot for a second screw. I used some stainless steel 8-32 countersunk screws with large area washers and self locking nuts on the bottom side.
So far it appears to be very stable. I’ll take it on a dirt road run this afternoon to see if there’s any shaking going on. While it makes the seat temperature control knob a bit harder to see, it really doesn’t make it any harder to use. The hand brake clears as well.
View attachment 3757643View attachment 3757644View attachment 3757645View attachment 3757646
