What have you done to your 100 Series this week? (46 Viewers)
rb4638 said:
And a Baja Designs led bar on my Slee bumper
What's the size on your LED bar? My next install is a bar like that on my Blueberry bumper.
I've upgraded most bushings on my rig with Super Pro, Whiteline, and Energy Suspension. Upgraded rack n pinion bushings with Super Pro. My factory rack n pinion was shot and so was the intermediate steering shaft. Got the DT cat back is already installed while in shop. Should have updated pics when work is done This Friday.
It's a 20 inch. I can't imagine anything longer fitting into this space. Pretty easy install using the brackets that came with the bar, just had to bend them to the same angle as the bumper.
Got my 20lb CO2 tank mounted on my rear ladder, cleaned my MAF in an attempt to mitigate my P0100 and P0110 error codes, and put some hose clamps on what appeared to be the source of my power steering fluid leak. All this in one evening after replacing the faucet on my kitchen sink... Busy night!
Sent from my Thunderbonner using IH8MUD
Got rid of a random CEL, VSC and VSC Trac off light by resetting the ECU, replaced the gas cap, new outer tie rod ends, new battery, cleaned the throttle body, and replaced the valve cover gaskets. Still to come, super pro steering rack bushings! And its only Wednesday!
Made a plexiglas wind fairing for my Gamiviti Expo rack. I used one half of a grounding clamp so it can be easily removed for cleaning. I was surprised at how much quieter it is at freeway speeds.
Did you fabricate the Roto Pax mounts for your ladder?
I had Mike at BIOR fab it when he made the bumper. Nicely holds those 4 cans (2 gallons each). Enough water for a week of camping, and spare gasoline just in case.
Bought a creampuff stock '05 LC last Saturday. Ordered new tires. In process of installing Sirius sat radio. Ordered a few parts to fix broken bits.
"Upgraded" from a '07 Sequoia. Will be a daily commuter with the occassional cross-country road trip with the family to New Mexico and California. At least now I can take a shortcut logging road over a mountain without the fear of getting stuck on a dry gravel road. :)
Magnaflow 18" oval...2.5 inch pipe inlet and outlet...2.5 inch pipe custom bent for higher clearance all the way back...resonator delete.
I was going to just get the EMS catback setup...but wanted to see this first as it was less than $300 installed with taxes. If not happy in a year or so...will consider selling this to someone else and replacing but so far I love it. Deep throaty sound on startup and initial acceleration without being obnoxious. Cant hear over tires and wind even with windows rolled up except during acceleration initially. :)
Think it sounds better in this one...maybe it is because you dont have to hold your head sideways to listen. LOL :)
Went from 1" body lift to 1/2". The collapsible part of the steering shaft was rubbing on my DT headers no matter what i tried.
Also installed 10mm custom spacers to clearance the UCA with the 35" MTRs.
And installed DT catback exhaust. Its nice :)
What did you use for the custom wheel spacers?
Here.
10mm, 103mm center bore.
I bought 4 of them, i think there 80 a pair, took about 3 weeks to get mine in. I may only need the front pair. I will see if my rear rubs this weekend at Super lift. If i don't rub, i'll probably sell the other two i bought.
Here.
Is there supposed to be a hyperlink "Here"?
I went crazy: 170k miles
Lubed driveshaft/Slip yokes with moly grease
Installed power stop roters and pads all the way around
installed wild west offroad lower control arms (had to pull out the mount b/c it was crushed)
Installed blisten shocks all the way around
Installed new sway bar bushings all of them
Installed new toyota cv axles
Installed new Hardline Fab rear upper control arms
Installed new upper control arms in the front
New lower ball joins
new bearings inner and outter
new seals
new tie rods
fix rust spots and painted the underbody with rust bullet
spent 3000k on parts :(
Layonnn said:
Doh, sorry, i copied it but forgot to paste it.
http://www.motorsport-tech.com/wheel_spacers.html
Thanks, Layonnn. Let me know if you want to get rid if your extra set, I may be interested.
Hoping to get my BL installed in a few weeks. Want to sooner, but will be out of town for work.
Got my body lift pucks fabbed up yesterday, waiting on the bolts to be delivered. Looking forward to getting this done, but not looking forward to taking out my drawers to do it!
Installed a TJM sump guard and transmission guard today.:D Not SLEE but waaay better than the stock plastic piece and at $150 if it saves me one expensive repair it'll be money well spent.
Do you have pictures? And where did you buy them?
