What have you been doing with your Toyota? (2 Viewers)
Mostly put back together finally. Still have clearance things to sort out but for now it’s a grocery getter again haha
Knuckle rebuild and electric to manual hub swap last week. Unfortunately I ended up short some brake line parts and couldn't finish the project, had to stick the Prado on the trailer to get it out of the shop for the next week while I wait on parts to arrive.
Another bunch of wrenching last weekend. Pulled the engine to check runout in the adapter plate.
While it was out I resealed the injection pump, replaced a couple of coolant flange o-rings and replaced the alternator.
Adapter plate was out by 0.019", going to get some offset dowel pins to dial it in. Target is >0.005".
Only took 4 hours to pull the engine, quicker than I expected.
Over the past month, the Tundra has been in the garage getting some much-needed love before winter hits. It got a full front end and while I was in there I noticed a blown shock on the driver's side so it also got new springs and struts. As I was finishing up I greased the u- joints and realized my carrier bearing was on its way out. So I then pulled the driveline and replaced all 3 u joints and the carrier bearing. I also removed the brush guard that I have never enjoyed. I got my studs on and finally got the sled deck loaded in🤘
  • Back
