Was the back side down to B Canyon clear? Thinking about taking the 40, two kids, a dog, and a cooler today
I have not done the pass yet.
Sorry I missed this. It was a busy weekend. Yes, it was totally clear, but you already know that.
I ordered a Ledfoot Racing Aluminum Fan Shroud, a SPAL 16” High Performance -2049 electric fan, and a Thermostat/Relay Kit from Champion Radiators. It’s described on the website as being a direct fit to the radiator that I ordered from the same place previously. Fedex actually delivered it on time, which I found to be pretty amazing. I had a full Saturday afternoon to install it. Should be easy.
I started out by removing the mechanical fan and spacer from the water pump. I realized immediately that I would need shorter bolts to keep the pulley on the water pump which means a trip to the hardware store. So, rather than spend all day making trips back and forth to the hardware store, I laid everything out on my bench and looked over the engine compartment to figure out what else I would need. The list came out to the 4 water pump bolts and 4 bolts and lock nuts to attach the fan to the shroud. Curiously, the Thermostat/Relay Kit did not include a thermostat switch, but no worries because I figured I’d just tie into the temp sender on the side of the block. (More on this later.) I made my hardware store run and got my parts. All is good.
I mount the fan on the shroud then unbolt the radiator from the core support. I go to mount the shroud and fan but I’m having some trouble fitting it all between the water pump, radiator, core support braces, and upper radiator hose. No worries. I remove the fan from the shroud and mount the shroud first, figuring I’ll just fish the fan in next, and this is where things start to go poorly. The fan doesn’t fit between the shroud and the water pump. It’s not even close. Like, inch and a half of interference.
Whoever did the engine swap on my vehicle positioned the engine quite far forward. This was probably done to accommodate the length of the transmission and transfer case and allow for the longest rear driveshaft possible. It would have also put the mechanical fan relatively close to the radiator, which is probably why there was no fan shroud. It worked “well enough” for driving around, even though it was totally inadequate for off road driving. What it means for me though is that there isn’t enough room between the engine and the radiator for an electric fan and shroud. I put a straight edge on the back face of the shroud and measured to the closest part of the water pump: 1-7/8”. SPAL doesn’t make a 16” fan that thin. So I’m feeling pretty defeated. I started looking into GM short-shaft water pumps, which would gain me about 1-5/8”, but would require a complete rework of the accessory drive. I pulled everything back out of the truck and set it on the bench, then I just stared at the empty space in the engine bay for a few minutes and I got an idea.
I made a trip to the auto parts store and bought a plastic zip rod fan/cooler mounting kit. These are the plastic rods that are used for mounting transmission coolers and such to the radiator. I used these zip rods to mount my fan directly to the radiator without a shroud. Then I wired it up following the instructions in the kit. Like I mentioned earlier, the kit did not include the thermostat switch, but I was able to splice into the line going to my temp gauge. I tidied up the wiring a bit, started the engine, and...the fan immediately came on. Hmm. That shouldn’t happen. Not until the engine gets warm. Oh. Right. The temperature sender isn’t a switch. It gives a signal all the time. Which is probably why I can hear my fan relay clicking every couple seconds. I definitely need to find a thermostat switch, but the fan works.
I unplugged the temp sender and let the engine warm up without the fan on. When I plugged it back in, the fan came on and the relay stopped clicking every couple seconds. I assume this is because the sender is allowing more current through at the higher temperature and this is enough to hold the relay closed. The fan was able to keep the temperature at the first mark on the gauge on the dash, which is where it tends to run at highway speeds on warm days. Normally it would go beyond the second mark on the gauge when left idling for more than five minutes. It was a pretty hot day, so I think this test was a success.
On Sunday, I tried to find a thermostat switch at the auto part stores in town. I didn’t have any luck. I found one on Amazon and placed an order. My “2-day Prime Shipping” is going to take 5 days to get here, assuming the shipping is on time. So, with some luck, I’ll be able to properly test the system next weekend. I also want to put in a switch to turn the fan off for water crossing or if it’s too loud at a drive thru, so I have some time to work on that before the thermostat switch arrives.
