1977, need to order pads and probably rotors any idea who makes this or if it's from a donor? Thanks
I didn't realize a 1977 had stock disc, OK, thanks very much!View attachment 3341304
I have the same. From my research it’s a later model landcruiser (most likely stock for your year and up)
I took off the caliper from the bracket and laid it on leaf spring with a zip tie in case my ankle biter came to the garage and got curious, had no idea the rotors are such a big deal to replace, got the bearings, seal and race, ugh.Looks stock so anything from when they started disc brakes up to and including FJ60. Mine is a 78 and used the parts for my rear axle.
You can get longer brake lines so the you don't have to break the line when every you service the hubs because the stock lines are too short.
I have it all but the 54mm socket, coming Wednesday, my knuckles are good, may do then over winter for fun. Thanks!Did you try NAPA, Red Line in CO, Man a Fre? Summit may also have them. SOR may have them but the prices will be high.
I replaced my rotors that I used on the rear but they are in better shape then in your photos if you are interested I will send you photos of what I took off. I got slotted rotors from Red Line for my rear axle.
