Ok, today was a little better. I drove 135 miles today with the family. Found out that my boost controller took a crap, and my new silicone vacuum hose to the gate had a restriction. So now I have the gate hooked directly to the compressor housing and I’m at 18.5 psi. I would like it to be around 22. Also I’m still hitting around 1250 egt, pre turbo, going up to the Lakes Basin from Graeagle. That long pull out me up on fluid temps too. Water hit 231, and oil 239. IAT, post intercooler, was 150ish. It cooled down really quickly once we got to the top.
Not sure what my mpg was, but didn’t use barely over 1/4 tank. I don’t really know what size the tank is, but I believe that it’s the same as all the 80s at 25 gallons. I have never put more than 19.5 in it with the light on for 30 miles.
We did drive in a little bit towards Little Gold Lake to see how the low range was working. I did click the lockers in. The rear sensor might be bad, because it never stops blinking. It definitely works though. I might be a tooth off though, I get a little sound when disengaging it. Sounds like a rubbing/clicking sound, but went away after turning back and forth while driving. The front works great! Engages quickly and disengages smoothly.
Even after quickly rebuilding the tailpipe, it still rubbed the tire when fully flexed out. This time a hammer will work.
Overall, today was good. Finally driving it after seeing sit in the garage for basically 4 months. Also met a fellow 80 owner (actually this was the first time I had ever seen another 80 while driving mine!) in Portola. He’s out of SF, and is a member of the the local TLCA.
