Johnny Joints work, but don't ride as well as rubber bushes. They will also need to be rebuilt at some point.No sense in reinventing the wheelCurious what you're ideas are though, Johnny Joints seem like they fit the bill
Not sure about "stronger" but the ride slightly better than heims. They are still a solid part that will not absorb vibrations like Rubber bushings, or even poly bushings. Yes whether bushings or JJ's, even heims, will need replacement. There is no permanent fail proof solution.They will need to be rebuilt, but bushings will need to be replaced... from what I understand the Johnny Joint is stronger and ride better than a regular heim joint?
I'm sure you've seen the Trail Tailor arms with the Johnny Joints, but they do have poly bushings in one end so not exactly what you're looking for. However, I couldn't discern any noticeable difference in free movement when comparing the JJ's with my current rubber bushings. I also, net the same amount of travel with both setups. The thing the arms with the JJ's have going for them is that they won't fatigue like a bushing will. I do believe the JJ's is likely more durable and will last a bit longer in high flex use than a bushing. But, as you mentioned they are not sealed and no real protection from the elements which, depending on conditions, could affect longevity. My guess would be that they would hold up fairly well in your location.Nothing protects JJ from the elements. Also Im not aware of anyone making upper and lower arms with joints on both ends with the uppers being adjustable with a jack screw. In the end they will be costly and Im sure not many if any are willing to pay the price but it what my needs are. In the end factory rubber is overall the best in value with "good" performance for most. Im just curious the difference with free movement in term of smoother flex, more flex and longevity.
“Without deviation from the norm, progress is not possible.”—Frank Zappa.
Easy coast = flat, try coming out west and going from 2500 ft to 10000ft in 25 miles with a boat behind your 3fe.
Love the license plate! lol
Taking it out of Park while you drive would help.One of these days I'll get through this pesky break in period...
The end capped with red crimp connectors is intended for an ARB bumper light which I dont have so it's just capped in the fender.Here's some pics of my Innovative Wiring harness to enable the parking lights to also be turn signals. Hope this helps someone looking to reproduce the results.
Where do you get this harness?Here's some pics of my Innovative Wiring harness to enable the parking lights to also be turn signals. Hope this helps someone looking to reproduce the results.
