@ToyotaDon is asking because the rear rotor comes off independent of the rear hub - as in it should simply slide off over the hub and lug studs once the wheel is removed. In your pic, the rotor appears to be stuck to the rear hub.Rear brakes.
I followed some of the power steering threads and tried one of the diagnostic tips suggested by a user...
Commenter: "...take off the reservoir cap while the engine is running and check for fluid flow."
OP Responds: "The fluid is bubbling. Not like air bubbles. Just fluid bubbling."
Commenter: "It sounds like your pump has taken a dump."
What was not made clear is that if your pump is (presumably) working properly, there will be an 8" smooth-walled column of fluid ejected from the reservoir and evenly distributed over your entire engine bay as a result of your momentary hesitation holding the cap directly over said column of fluid.
So now I need to know what is a good cleaning agent to spray this crap off...
edit - and to those who saw what was coming before even finishing reading...kindly keep it to yourself. lol![]()
Guess the 37s wont be going on tomorrow... The chef at the restaurant tried to put it out, said sparks were falling from under the hood. The battery was completely melted. I have no idea what happened. We were parked at the back of the restaurant, the fire department was cutting the hood open while my wife and I ate cheesecake. The manager came and asked who drove a white fj80, thought I was going to get another compliment as I do at most places... No idea the extent of damage as of now, will tow it to my shop tomorrow and check it out.
Hopefully salvageable for a ls swap? Not sureMay have been a dead high-current short. Stuck starter contacts are one thing that could cause it. I'm afraid it's a total loss.![]()
Yeah I did that - thanks - will have to tear into it when I get back home from sub zero!Pop the caps off the top of the wiper see if tightening the nut works, mine use to loosen up then not allow the wiper to work
if there's ever been a more prevalent time to do one I'd say now is that time, Sir.Hopefully salvageable for a ls swap? Not sure
Started some of the body repairs. Used POR15 to fix the rear lift gate rust areas. Still looking fir a good, complete front axle kit. Any suggestions?
Rear brakes.
A properly bled and functioning power steering system should not puke fluid like that with the engine running. You should be able to look down into the reservoir and see the fluid churning and flowing, but there should be no geysers.
This misunderstanding was my second guess. @incogrhino The rear brakes on the FZJ80 full-floater do not require hub & bearing removal to get the rotor off. As long as they are not too rusted, you should be able to slide the rotor off, leaving the hub in place. Now that you're there, you'll probably want to see whether the rotors should be replaced, and you can go ahead and pack/replace the bearings too.
I feel the pain. Mine just snapped in the polar vortex plus frozen door. Now for it to warm up enough I can replace it!Now we can add driver side door handle snapping off in my hand this morning!
