I mounted, tweaked and fitted, then removed the
@kelly saad headlight and grill assembly. I need to make a few more tweaks to the headlight mounting and then get it deburred and powder coated. I'm using the Dapper Lighting 7" Honeycomb which is the cheapest glass/metal HID compatible projector lens I could find. Plus the honeycomb pattern and size will match my final grill with the larger honeycomb pattern (it's on order with the metal shop). I'm running a 130w Hella H1 bulb in it right now but I will swap to a 35w HID kit later on. The beam cutoff is amazing but it's still just Halogen. Interestingly, I can't tell much difference between this 130w H1 bulb and the 900x HIR bulb. I setup both bare and they look about the same. The difference is in the beam pattern.
Next I installed white/amber switchback bulbs from Amazon (the black ones in the pic)
https://www.amazon.com/gp/product/B07KWNSKJK/?tag=ihco-20 into my corner markers/signals which I've adapted into turn signals. WOW, the light output is amazing. They are bright white all the time until you turn on the signal then they flash off/amber so much brighter than my sad little turn signals in the valance. They looked like they were flickering, not flashing. Those bulbs alone knocked 20 years off my truck! I'm going to replace the rear turn signal bulbs now (amber only).
I'm also going to replace the long amber turn signals in the valance with a set of clear with another set of the switchback LEDs as soon as I find a quality set of lenses.
Next I installed new red LED tail lights (the grey ones in the pic)
https://www.amazon.com/gp/product/B07GYL5X7H/?tag=ihco-20. Amazing. They now look like my old brake lights. My brake lights are crazy bright (as measured with a crazy meter). I don't have a pic of the entire truck, just bulb (driver) vs. LED (passenger).
Finally, I put the OEM headlight and grill back on. Tested the new Dapper Lighting projector headlight against the OEM and boy, what a difference the beam pattern and cutoff make. (no pics, my test wire broke before I was finished).
