What did you do with your 60 this weekend? (16 Viewers)
I get a weird thing though when the choke is fully pulled that it starts to idle really rough until I push in the choke slightly then the idle smooths out.
My carb behaves the same...I believe it is improper functioning choke opener, but haven't been able to prove it. If I do a carb tune-up, as I reset the fast-idle at the last step, it will hold steady at 1,800 rpm (with the choke fully set)...but then go to start it the next morning and that strange symptom returns...starts fine, but right after begins to decel/stumble a little so I have to push the choke in to 1/2 way.
Yep. Or half, or 1/4 or not. Nothing in that area seem to make a difference and after you've cranked it a while you can smell gas.
Which again, inclines me to think spark.
Well there goes my theory. I was thinking that if the choke breaker wasn't working then when you started it up on full choke it would fire but then die because the engine couldn't get enough air. If you have the same symptoms with partial choke then it isn't that though.
Been thinking about crud in the carbs but didn't know you could get to the mains through those plugs. I'll try that..
They are easier to hit with the air horn off, but if you've got super powers you can hit 'em through those plugs at the base of the fuel bowl.
Might also consider hitting the 4 vac ports on the PS base of the carb...and even the fuel inlet (where the screen is, so be careful there)...you could remove the idle mixture screw and spray that down (where needle valve assembly is) and if you had a real fancy red straw that curves (like the one sold with Seafoam), you might be able to get the ports in the walls of the primary and secondary barrels...
Heheh, I don't think it's the choke breaker or one of the many vacuum ports.
I've got a Trollhole carb and have only one vacuum port and no choke breaker. Well, I suppose you could say the choke breaker is that thing with the fingers on the end of my left arm. :)
Could that be the decel solenoid? CCOT has them and they're not 'spensive.
http://search.store.yahoo.net/coolfj40/cgi-bin/nsearch?catalog=coolfj40&vwcatalog=coolfj40&query=decel solenoid&x=0&y=0&.autodone=http://coolfj40.stores.yahoo.net/mirfjfjcharg.html
Hm. Maybe that's my problem. Then again that's a spankin' new solenoid and it ran/started fine until the weather cooled off.
Got back to my parents house to fetch the 62 and get new tires on it. The shop ordered the wrong ones though :bang:. Riding on General Grabber HST's until Thanksgiving when I can get the Grabber AT2's put on it. Also did a little cleanup on the wheels.
OOOOhhhhh... do tell on what you used on the wheels. Mine are slightly rusty but would like to clean them up and possibly coat them in the Never Wet stuff.
All it took was about 15 minutes per wheel with the wire wheel on the drill and wiped them down with acetone after. Way less work than I was expecting!
Began the tear down... The "while I'm in there" list is growing.
RUTROH RAGGY!!! @rmblaire you are getting after it aren't you?! Did you decide on completely rebuilding your current engine or swapping?
@LATechCruiser Just a normal wire wheel or did you find one that was a smaller grit (if that is a thing with wire wheels)?
Hopefully the problem is just the crank pulley/harmonic balancer. If so, I will be putting it back together and running it fr a while. A friend of mine found me 2 free small block chevys so I plan on building one of them and gathering parts for the swap.
I bought another 1985 tan one just before the weekend. Towed it back home from Sacramento to SoCal. Changed the starter, plugs git it smogged and had a new flowmaster muffler installed. Then I talked my wife into detailing it. Tomorrow I'm picking up parts from Ruffstuff to do soa/ct.
just installed my dual battery painless system and about to convert to the cs144 alternator when it shows up should be fun if i don't burn it down.
Finally got my Trailfields and 4:88s in. Replaced the felts and inner axle seals while I was in there.
Dropped her off at the shop for:
Desmog, R&R steering components (tie rods, relay rod, steering gear box, ps pump), thermostat, water pump, hoses, header, new custom exhaust, shocks, bushings, mean green alternator, mean green starter.
And then will rip the engine out next year for a transplant 5.3/6.0 - the madness, make it stop =)
Recommended you reach out too NCFJ here on MUD he's finishing up my 5.3 Repower! Consummate professional with a wicked eye for details! Ended up being a frame off restoration! Best of luck! You have a great looking rig! Thanks for your service!
