What did you do with your 60 this weekend? (1 Viewer)
Went up Kennebec pass west of Durango with :princess: and dear friends to spread my mother in law’s ashes. RIP!:angelic::angelic:
I have this in front of me this weekend. Did you have to remove the upper radiator hose and thermo housing?
You might be able to get in there with nimble hands. If I remember correctly, the belts are more of a problem. It's a 17mm I think. I had one that was fused to the thermostat housing so I just left it as is. Not broken just cleaning things up and replacing thermostat, gaskets, and whatnot.
You don’t have too! You can keep the top housing on. Disconnect the upper radiator hose from the housing and twist so it points up. Belt is in the way but you can still get to it with a long open end wrench. If your replacing the bottom one remove the top one. Just be careful not to break the nipples.
I was lucky enough to get my fuel tank changed at my local dealer as part of the 1990 recall...I paid for the fuel pick up so everything touching the fuel would be changed as I had fresh gas put in after the new tank was installed. Stumbling a bit after I got it back so decided to change the fuel filter and open up the jets a bit. I knew this needed to be done ever since the desmog and having the weber installed. Found some dirty fuel in my carb. Running great now. Truck is awaiting the H55 combo I ordered from George at Valley Cruisers....can't wait to get my 5th gear and having a quiet tranny.
Also had clear tint installed last week....even had them put it on the windshield. Supposed to cut down on 95% of the heat. I have not had enough sunny days to review it yet, but will in the next couple of weeks.
Looking good !
Clear tint?! That sounds awesome! Very interested to hear your opinion on how it works!
Re-dipped the truck. Got about 2 years out of the rattle can job I did last time - also bought a cover to hopefully get a few more years out of this job. Used a real gun instead of the cans...although I had to do it in stages, so the color wasn't a perfect match everywhere, but it looks better then before which adds 15 hp and 3 mpg, as we all know. Also bled my new clutch master cyl properly, so it works much more better now. And then, for no particular reason, I took her for a drive.
Spotted this beautiful 60 in a parking lot in placerville CA, anyone know the owner?
This worked perfect, tks!
Did some hurricane clean up :frown:
Bummber. Glad you're okay. Is that the extent of the hurricane damage in your life?
