What Did You Do With Your 120 Today? (16 Viewers)
I was looking for just slotted when I was shopping, but this is all I found EBC offers as a kit. So far I've been very happy with the same style on the front (EBC kit) and decided to continue this trend on the rear. Note these are not fully drilled, but dimpled. I've stayed away from a fully drilled for reason #4 you listed. Since this isn't my daily I'm not as worried about the lifespan of the pads (put less than 5k on the car last year). All that being said I do appreciate the insight and will take it into consideration when it's time for new parts. Certainly if I have any failures or issues I'll report that out as well.
I swapped back to solid rotors when my pads wore down within 20k miles on my gen1 sequoia. I tow our pontoon and do excursions to the Sierras attributed to its early demised.
Power Stop Z23
Old fluid in container, old fluid splashes vs. new, and reservoir looking clean. Only removed the return hose and ran about 3.5 quarts through. Used the front wheels of the ground lock to lock method. Don’t think this was ever done. Had no steering issues just knew it was time.
Scored a set of FJ Cruiser Trail Teams Edition Bilsteins yesterday off FB marketplace for cheap. Couldn't find any tool marks or signs of use anywhere on them aside from rolling around in someone's garage. The seller didn't know anything about them as they were tossed in with the purchase of his FJ. He was under the impression they were for a Tacoma.
Later at night after getting home, I took a closer inspection at the spring perches and noticed the typical 5100 circlips but no other grooves for them to adjust to. Granted, that was before heading to bed to satisfy curiosity so I could've overlooked something in that boondoggle.
How hard was it to stuff those tires in? I have 35 Kendas and I've been pondering going to the 37.
2" Body lift saves a lot of cutting, then it's just trim this and that.
2” body lift made it easy (that’s comes with its own challenges), there was still
Some cutting, and a BMR was needed. I moved the axle back about an 1” with the metal cloak links to keep it out of the back doors.
I’ve read that these 37’s run small but have had nothing else to compare it to at the moment. They measure 36”+ sooo. We have no trips planned until early spring so I listed the tires on FBM.
Details on the lights?
Yes, Teq Customs. They make a lot of headlamps which look to be US made. Seem very quality. Mine are the plug & play halo ones, plus they have a more customizable version I believe too.
Took 8 weeks as they stated. They are spendy but I generally shop for quality and not lowest price point if I can.
The looks transformation is incredible.
I did have to drop my bumper about an inch to r&r the lamps - the hardest part…
Thanks for asking.
Exchanged 10 quarts of ATF at the cooler.
181k miles and pretty sure I broke the factory torque mark on the ATF level check bolt. Removed it at 97F and about 1/4 quart drained.
Thanks to all of the how-tos out there. The last how to I found the guy said I’m not fooling with a pan drop, drain bolt, & drain fill bolt. I agreed.
When I get a Nomad valve body the screen, solenoids, & wire harness, can be swapped 😎
Did some earth moving with the Dingo rental from HD. ATF temps soared breifly on the slow climb home. Trailer height was about 12” off the ground and I had to use the GX air springs to hitch/unhitch.
Installed a SS Budbuilt Diff Skid- F'n thing is like a piece of artwork and you can "beat the snot out of it".
2008 Lexus GX470 Mods - Starting Jan 2022
  • Icon 0-3.5" Stage 4 Suspension System w/Tubular UCAs
  • Rad Rubber Design Engine Splash Guards
  • BFGoodrich Mud Terrain T/A KM3 LT285 /70 R17
  • RSG Metalworks Angled Sliders With Logo Top Plate **No Kick Out**
  • DeMello Off-Road Stealth Series Front Bumper w/light bar cut out
  • Smittybilt X2O 10,000lb synthetic rope, wireless
  • Baja Designs S8, 30" Driving/Combo, LED Light Bar Amber
  • Baja Designs Squadron-R Sport, Pair Driving/ Combo LED (Clear)(Bumper)
  • Baja Designs Squadron Pro, Pair Driving/Combo LED Ditch lights
  • JWOffroad Ditch light brackets
  • Unique Style Racing JDM Style Matte Black Housing with Light Smoke Lens LED Tail Lights
  • OEM Driver and Passenger Headlight Lamp Sport Package Upgrade Smoked Tint, Black chromed Reflector with LED bulbs throughout
  • HID Kit Pros LED Interior Lighting Package
  • Metal Tech Pegasus Rear Swing Out Bumper, Flange Mount backup LED Lights, Standard Rear Receiver, Backup Camera Mount Kit, License Plate Holder
  • RA Motorsports Moab Edition (Reinforced) Aluminum- Front, Transfer Case, Transmission (Mid) Case and Gas Tank Skid Plates
  • Magnaflow Overland Series Stainless Cat-Back Exhaust System
  • Ebay Artinism GX Cupholder
  • Blue Dog DesignWerks Transfer Case Shifter Surround Panel
  • SDHQ Built Complete Billet Battery Terminal Kit
  • SDHQ Switch Pros SP-9100 8 Switch Panel Power System
  • Powertrays Switch-Pro Accessory Bundle, Switch-Pros Powertray
  • Phoenix [G6 OCTA-CORE] 10.4" Vertical Screen Android 11 Fast Boot Navigation Radio
  • Rago Molle Cargo Cage - Cargo Net Replacement
  • Tinkerer Design Studio Ranger Series Shift Knobs
  • AEM Dryflow Induction Filter
  • K&N Dry Cabin Filter
  • Harrop Eaton ELocker - Rear Differential
  • Toyota OEM Rear Driveshaft
  • Timbren Offroad Bumpstops Rear
  • Perry Parts Front Bumpstops
  • Icon Rebound 17”x 8.5” Satin Black Wheels w/ Wheel Protector Kit
  • Yota Nation Under-Hood LED Light Kit
  • Rear Diff Breather Extension
  • Wits End Extinguisher Bracket and H3R Purple K Extinguisher
  • Center Console Dedicated USB Outlet USB C Charger Socket
  • Overland Custom Design Rear Heim Joint Anti-Sway Bar Links
  • Icon Front Coilover 700lb springs
  • Garage Alpha TRD Style Grille
  • Modified/installed LFD Offroad ARB mount (2010-2022 4Runner)
  • ARB CKMA12 On-Board Air Compressor High Performance-Passenger side mount LFD Offroad
  • Harrop Eaton ELocker - Front Differential
  • Removed Front sway bar
  • RCI Lower Link Skids
  • Rear Nolathane 24mm HD Rear Sway Bar
  • Rago Heavy Duty Group 34 Battery Box
  • Odyssey Group 34 Battery 850cca
  • Dr KDSS BOTCK and TracBar
  • Rear Jowl Recovery Split Shackle ¾
  • MBP Tuning (Moddedbyphil)
  • Fumoto Oil pan Valve
  • Simply Speakers Mark Levinson Complete System Speaker Repair Kit FSK-GX470
  • BudBuilt Rear Diff Skid
  • Not Completed Mods
  • Clean and Detail underbody/chassis
  • GX460 Front Brake Mod w Powder Coated Toyota Calipers/ EBC Rotors
  • GMRS Radio wiring to center console (future mod)
  • Troubleshoot Back up cam
Finished the job the PO started when he converted to coil springs.
Also installed this switch panel from Blue Dog Customs and the VSC/TRAC disable switch from SBE Precision.
Behind that switch panel is the Diode Dynamics CF18 relay (not smart tap) that I tossed in while I had the dash apart.
quick question...which one of the factory buttons light up when the headlights are on? my seat heater light recently burned out and it's making me wonder which ones have also gone out
Some moron in a semi put started backing up at a stop light. Put the corner lift gate into the truck.
Hood ordered. Lights ordered (needed em anyways.) Steel bumper with full hoops ordered.
Soon as all that gets here, I’ll swap everything out and it’ll go the body shop for fresh paint all the way around. Already in it at this point.
Also, pretty sure the only reason they didn’t total it (4.5k in damages) is because the estimator put 30797 for the mileage. They missed a digit…
