What Did You Do With Your 120 Today? (9 Viewers)
Is this fender to ground? Could you extrapolate what it would be fender to center of wheel hub to remove tire size/pressure variables?
The measurements are fender to ground on OEM type 265/65r17. I can’t extrapolate. It’s illegal in Georgia.
Getting the fronts in!
Congrats! It'll blow your mind what its capable of, even stock!!! 😲🤘
Enjoy, and sweet pix!
You are sooo right. We had a 2016 Tacoma four-wheel-drive, and now a 2018 four-wheel-drive tundra and it is absolutely amazing with this thing will do.
Finally got a chance to tear into my GX for the first time. Got my Depot Sport HL assemblies in over a week ago and I've been dying to find the time to install them. Old headlights were pretty faded and one of the clips was barely hanging on. I also upgraded to using LEDs bulbs for the low beams and luckily ordered two sets. I say "luckily" because on sooner had I put one in and tested it out it fried itself. Slapped in another one and it's all good. Really happy with the output.
It arrived! Totally worth the effort to see those boys smile :)
Swapped the impulse Treaty Oaks for some take-off Trail Tailors.
Shackles dont fit the TO (they list that but i didn't understand those details when i impulsed them a couple years ago) with factory tie downs (06+) in place... Shackles fit in TT's though, no cutting necessary.
The TTs are also a little routed providing a smoother edge and would be more gentle on soft shackles. The TO are 90s and a soft shackle does fit, but just BEARLY... TO could do MINIMAL CAD redesign to get these to fit 06+ tie down (not everyone wants to cut off those stock loops).
I replaced my PCV valve last year just as a quick prevent maint deal, and found that the spring clamp holding the hose on was loose and was dumping oil into the valley on on the intake mani mounting flanges. So I cleaned it up as good as I could and put a new clamp on it. Hoping that fixes the burning oil smell I have had for few months.
Also cleaned up the MAF and air filter. I am replacing the OEM Airsprings with Arnott this wknd, and having the transmission fluid exchanged at the stealership tomorrow. It's got close to 180k on oem bags, and it's been 60k since the transmission fluid has been changed, so I figured it time to replace. We tow a 19' hybrid travel trailer 12-15 times per year, and I really don't want to have to drive it home with blown bags or a major leak.
