I used a window air conditioner foam insulation kit from Home Depot. Foam was like 2" square by 3 feet long.Is there a PN and a certain location you sourced this foam from? I was thinking of filling that void with a rubber hose.
I used a window air conditioner foam insulation kit from Home Depot. The foam was like 2" square by 3 feet long.
I went with this oneIs there a PN and a certain location you sourced this foam from? I was thinking of filling that void with a rubber hose.
Those of you that have replaced a brake booster on an 80 know that you often have to loosen mounts and jack up your engine a bit to clear the intake manifold and get the new booster against the firewall. Good mechanics will accomplish this by wrenching on the isolator lug nuts in a counter-clockwise manner but not me. Last week I started on th DS upper mount and cranked on that sucker--clockwise, unfortunately--with my 17mm socket and breaker bar until, you guessed it, I sheared off the lug. It was early and in my enthusiasm I had begun without any coffee. Learned THAT lesson--oh, and that "lefty-loosey" one too.
My new mount arrived promptly from NLXTACY at Wits End along with some caliper bolts (who hasn't thrown a bolt and scavenged one from the rotor?) and a very sexy 1FZ-FE engine name plate. Tonight I removed air filter housing and intake, forward exhaust manifold heat shield, loosened PS and transmission mount nuts, and removed DS lower mounting nut without incident. Removed fan shroud bolts too. Tomorrow I'll find a scrap of 2x6, jack up the engine, replace the DS mount, and install that brake booster (you remember the brake booster?).
Damn I'm speedy and efficient!
Where did you get the Home AC foam? And is it all around the front of Radiator?Finally got around to replacing my radiator. TYC with home air conditioner foam @LandCruiserPhil suggested in another post.
This actually made my AC run cooler than using stock Toyota radiator.
@Just Diddly, your rig is looking great! And, now that you got it all pretty for the holiday weekend... get out there and used that premium camping setup!
I went with this oneWhere did you get the Home AC foam? And is it all around the front of Radiator?
Finished up the drawer system I got from @PitchSolid system with two drawers, folding/flip up storage area, some foam padding on top, and quality hardware. It seems however, that whoever built them originally made everything half an inch too wide. Plan was to originally add a couple of supports to stiffen up the slightly warped side wood and make it more stable of a platform to sleep on, but because everything was a tad too wide, the supports made the whole thing too rigid to fit between the wheel wells. We were able to get away with a single small 8" wide plywood support on the bottom connecting one side to the center divider that gave enough pressure to keep the drawers in their tracks but still able to open without too much force. Sanded all the wood, removed some of the blackened/mildew areas, then covered in Killz primer to manage the musty wood smell. Overall, with only about $50 in wood and paint into the whole system, I'm pleased with it. Wont be a permanent/forever solution, but until I graduate and have more available fun monies in a couple of years, it'll do great.
Also, decided to clean, polish, and hand wax the rig for the first time and put some UV protection spray on the awning and tent to help restore the color and give an extra layer of defense against the hot AZ sun. Oh, also fixed my passenger mirror, so happy about that.
So is the black truck going up for sale? Wheels and Nittos are installed, thanks for the deal!Got the Weber 38 carb installed in the '80 Hilux. It runs SO much better than that wonky Aisin that was on there. So now it runs, idles, and thanks to the Historic Vehicle ahem, rule, it's registered and titled in AZ. Got to keep the cool Utah plate, too.
