Sweet! Looks I don't have. ThanksI don't know the specifics of each market but Japan had FTs with and without EGR (might depend on the region?), Europe had EGR, and Australia didn't as far as I know.
w/ EGR:
w/ EGR:
I did a lot of searching and it looks like a no for Toyota shims. There may be off brand kits in AU, but I haven't researched that too much. I think I may buy extras for future use after I do this engine. I did the same for the 1FZ-FE and have a bunch of those shims- though I can't seem to locate them.I've been wondering... is there an alternative source for valve shims? The Toyota ones are all 3-5$ apiece and just having the right ones on the shelf when you need em adds up quick. Seems like a part where there would be some good aftermarket options, considering these shims are all the same in H and L series engines.
Darn.I did a lot of searching and it looks like a no for Toyota shims.
I have been getting more organized after many many instances of losing small parts. I bought these old metal library card holders and built my own janky shop furniture out of it. Absolutely worth it.I did the same for the 1FZ-FE and have a bunch of those shims- though I can't seem to locate them.
I need to get my messes in order!Darn.
While organizing, I "rediscovered" many items I haven't seen in awhile![]()
there are several different compines that make aftermarket ones but they're not that much cheaper. Even if they were i wouldn't chance it there is alot force being applied to that shim by the camshaft. i would want it to be just right so it doesn't damage the cam.I've been wondering... is there an alternative source for valve shims? The Toyota ones are all 3-5$ apiece and just having the right ones on the shelf when you need em adds up quick. Seems like a part where there would be some good aftermarket options, considering these shims are all the same in H and L series engines.
I say that every day, but never seem to make any real progress.I need to get my messes in order!
You made me think of something else with the fact that new shims will be going in there. Is it recommended that a high zinc oil, or even better, a zinc additive be used so the cam cam break in to the new mating surface? It is gospel on a new engine. Seems to make sensethere are several different compines that make aftermarket ones but they're not that much cheaper. Even if they were i wouldn't chance it there is alot force being applied to that shim by the camshaft. i would want it to be just right so it doesn't damage the cam.
zinc additives can mess with your oil's chemistry,You made me think of something else with the fact that new shims will be going in there. Is it recommended that a high zinc oil, or even better, a zinc additive be used so the cam cam break in to the new mating surface? It is gospel on a new engine. Seems to make sense
I put a little flat tappet cam grease on new shims. For what ever reason American OHV engines have tons of issues with cams being wiped out but I've never seen an issue on a OHC Jap engine that wasn't staved of oil. I wouldn't add anything to the oil personally, If anything use an oil with more zinc already in it.You made me think of something else with the fact that new shims will be going in there. Is it recommended that a high zinc oil, or even better, a zinc additive be used so the cam cam break in to the new mating surface? It is gospel on a new engine. Seems to make sense
I have a buddy that restores high end muscle cars- they were breaking in an original 426 race hemi on a dyno and it ate the brand new cam up in an instant as they shut it down. Fortunately, they saved the engine. High detail and every precaution and it still happened. I was terrified when I did the cam break on on my number matching 454 in my Chevelle.I put a little flat tappet cam grease on new shims. For what ever reason American OHV engines have tons of issues with cams being wiped out but I've never seen an issue on a OHC Jap engine that wasn't staved of oil. I wouldn't add anything to the oil personally, If anything use an oil with more zinc already in it.
What's the story on this one?
Just out of curiosity, it the marking in cylinder #1 light enough to call good? It looks like it, but I honestly don't know the limit to where you can call it good or not. Thanks for the pictures. Looks like a cool projectFT in an HDJ81 that came in for,
Gturbo
+30 injectors
250hp pump
PDI intercooler
ARP head studs
Rebuild head
3” exhaust
Timing belt & water pump
EGT & boost gauges
Upgraded fan clutch
Few other things
Cheers
