What Did You Do To Your Diesel Today (WDYDTYDT)
OGBeno
23303-56040
Moderator
GOLD Star
Patagonia, Arizona, USA
Hey all:
This section of MUD doesn’t have a thread where we talk about the mundane, the arcane, and the run-of-the-mill stuff we do to our diesels on a daily basis.
So I figured I would start the thread. Post up what you did to your Diesel engines today.
Tore down a 1HD-T today in preparation for rebuild. :)
Finished charging the batteries again for the 3rd time this year so I could go for a drive after doing front Ujoints. Coincidentally, I've only driven it 3 times this year.
Got a pair of Odysseys that are going in, but I'm in the progress of making some battery boxes first. Soon, it will look much nicer.
Oh, and by 3 times this year, I mean since January. I don't neglect the truck that much.
Test fit a 3rd manifold for turbo fitment on the Cummins - so close but my steering box shaft got in the way. So I gave up and bought the adapter that works on the factory manifold.
After consulting on parts needs with Don @Onur who is apparently neck deep in 1HDT rebuilds, I parked Ochenta, my HJD81 for an upcoming head gasket replacement (and some while you're in there stuff).
Then started prepping Righty, the BJ74 for an upcoming trip to Death Valley with @Dan2722 and @bushdoctor . I haven't driven the BJ74 much lately, so changing engine, diff, and tcase oils, adding a transmission temperature gauge, retorquing this and that, topping off fluids...should be ready to go.
Thought about what kind of engine oil to put in my 1979 B engine 🧐. Any suggestions?
Oil, preferably clean. The B isn't smart enough to know any better. What temperature range is she running in?
On Sunday I got the new timing belt installed, set the IP timing, installed new injector lines, replaced the rod bearings, applied some assembly lube to the cam (this engine has been sitting in storage for a long time), then threw on the new valve cover and timing cover. I stopped short of putting the new oil pan on since I couldnt get to the rear main seal while its on the stand, i'll get those two things while its on the hoist. Also bolted up the new throttle linkage assembly (was missing when I got the engine), which was cool to piece together from individual part numbers.
Slowly making progress towards having this thing ready to drop into my 60.
🤣 depends how fast I go. 0-45 sits right in the middle. 45-60 about 3/4 up the gauge and coolant starts shooting out. I’m in Southern California so air temp is pretty nice. 70-90 F all year long.
View attachment 2616196View attachment 2616197
Nice.
I did the throttle lever as well the other day.
Rightio, a decent mineral 15W40 then. Was referring to outside air temp rather than engine coolant temp. If you go somewhere cold, as in zero C or thereabouts you may want to go to something thinner but if you're in warmer temps year round, go for the 15W
Wow that'd take me a month to do all that
Its definitely a lot easier when its on an engine stand and not in a truck! I've been storing this at a friends property about two hours drive from where I live so I try to make each trip up there count.
