@YotaFun where did you get your power washer sandblaster and how did you like it ?
Thinking of get one to do some Tacoma wheels myself.
Thanks
@YotaFun thanks for the feedback and info@VA.CRUISER
This is the set up I bought from Amazon:
Angela&Alex Pressure Washer Sandblasting Kit, 5000 PSI Wet Sandblaster Attachment with Goggle, 1/4 Inch Quick Disconnect Sandblasting Kit
Its alright, not the best, not the worst, makes a mess and is not very accurate. I changed out the red hose it came with with some clear hose in the same size and got better hose clamps because the ones in the kit are junk.
I feel this is good for larger areas or on something that you don't have to be too precise with. But it did get the job done.
The one thing I noticed and will probably remember for the next time around if I end up refinishing these wheels again or another set of wheel, the metal itself is very pours underneath the paint. I think either a skim layer of body filler or some kind of enamel paint (maybe) needs to go down first. I did about 5 coats of primer and 6 coats of paint and the spots that were heavily corroded and that I blasted just kept sucking the paint in more and more, even the clear as well. So these wheels aren't turning out the best but will be better then the wheels I have currently on the car. I will get pictures posted later for reference.
Took the truck out for a quick spin this morning. The good news is - I have dash lights
the under dash light and heater control lights are green.Yeah I'm actually looking forward to it. I have the headlight switch out again trying to diagnose the headlight issue so I haven't actually seen them at night yet. Whats with the weird green glow?
Heater control lights? You mean you don't just have to reach blindly into the abyss to change from right-leg scorching to hot wind in face to mediocre-at-best defrost? What's the fun in that?
i fancy the finer things in life...power brakes, a clutch pedal and dash lights.
Thanks @YotaFun I won’t be as concerned because mine will be on the crawler so rocks will chew on them anyway some but nice tips for cleaning/paintingDecided to do a little beauty update to the Lexus. (Bottom 1/4 of the car)
The paint job on it is junk. The car use to be a beautiful emerald green, and after the accident it was in the previous owner had it painted white but must have got a friends special since none of the old paint was prepped correctly and it is starting to chip up everywhere. I think its a nice little touch, almost gives the car the older fairlady style (that is a stretch in description I know)
Finally had the new tires mounted to the wheels:
And drove it to work:
I'll get some better pictures later. but the car sits about 2 inches higher than before. The car had 225/45R17 which is about an inch shorter than factory, and now has 225/55R17 that is an inch higher than stock. I feel it has a really nice stance now (but I like all things lifted...) and is so much easier to get in and out of now. And the vibration I had 60 on up is gone! It is not as smooth as glass but it is so much more better and I actually enjoy driving the car even more now.
This will probably be my new daily to save putting mileage on the Tundra, everything in the car works now, everything including the heated seats and the rear defrost (weird things to mention I know). The only other things I would really like to do is put in a different head unit with android auto at least and an exhaust system which will probably be a next spring or summer project since I would like to do headers back and build my own.
@VA.CRUISER these pictures don't do it justice but this is what I mean by pours on the wheels:
Still feels sandy and unfinished even though there is multiple coats of primer, paint and clear.
You notice the bullets. I saw the pad lock and have questions about it now. Vintage anti theft system?also, are those bullets in your heater vent?
