What are you working on?
I have heard good things about Seymour from the flex rocks and rollovers YouTube channel. Will try them next. @matzell i had some issues with a couple of the cans of hard hat enamel. The ones that worked were great but others wouldn't spray right...
Did you clean the nozzles etc?
I have had one or two have the straw fall off. I turned them upside down to spray.
A alignment and new shoes for the old girl.
Andddd now I'm replacing a brake line. Nicked one of the long rear hard lines w the grinding wheel and sure enough it burst as soon as I touched it.... parts car to the rescue as long as I can snake that pre bent line correctly through/around everything.....
Sheee-it it’s hot out. New 17s from @matzell are coming right back off to pull out differential on another day, but for the sake of the neighbors, trying to at least have two tires on the ground on all the various vehicles in my front yard.
Found the source of my fuel leak when topping off & (as I found out at Relic) going up inclines with a tank more than halfway full: rubber hose between metal filler tube and tank was dry rotted and split at the top. Part was cheap and replacement was relatively simple, just another exercise in various 80-series yoga poses to access.
Nice when there is an "easy" fix!!
Base plate for drawers
Meant to say this yesterday, but if you need to make a new line, i’ve got flaring and bending tools you can borrow. The soft coppery stuff they sell now is super easy to work with.
I appreciate that. Might hit you up if this factory line doesn't go well. Still might hit you up in the future as all of my lines need replacing at some point...done 3 or 4 of the hard lines so far need to just get to all of them
Base plate installed and fridge slide mounted
If you want some 36inch locking slides I have an extra set
may take you up on that. Full extension? If so let me know what you want for them
