thatcabledude
GOLD Star
Did you not read the thread?Thanks for the update but still looking for that factory ez button replacement. Else I’ll try to find a working stock speaker.
I put some Sony speakers behind my factory grilles. They were a little too deep on their own so I installed 1/4" spacers behind each one and lightly trimmed the backside of the grilles. Looks 100% stock on the surface.
It's those for the front and I epoxied the 4" Sony rears into the factory plastic spacer rings in the back. All in all, a healthy afternoon of work. I can get pics later
Looks superb!Here's the finished product, well 4 years after it was finished. They're still great
Do you know the model name/number of the Sony 4" speakers that you used?I put some Sony speakers behind my factory grilles. They were a little too deep on their own so I installed 1/4" spacers behind each one and lightly trimmed the backside of the grilles. Looks 100% stock on the surface.
I can try to dig it up, but it looks like Sony isn't making 4" speakers anymoreDo you know the model name/number of the Sony 4" speakers that you used?
It was these thoughDo you know the model name/number of the Sony 4" speakers that you used?
The 4" pioneers I mentioned above fit the rear doors.Do you know the model name/number of the Sony 4" speakers that you used?
Thanks!The 4" pioneers I mentioned above fit the rear doors.
This is what I ran. The factory speaker is super shallow with a wonky ass, barely-there magnet to avoid contact with the window track. The Pioneer fits with relatively little drama. I used a 3" hole saw to remove the back of the factory plastic speaker basket, drilled new mounting hole in the new speaker surround (to align with the OEM screw holes in the basket), and soldered the OE speaker plug onto the +/- leads. Sits flush behind the factory grill without a spacer. Aside from the dramatically improved sound, you can't tell it's not factory.Front doors: Pioneer TS-G1644R
Rear doors: Pioneer TS-G400
Front dash: Pioneer TS-A878
Thanks for posting these part numbers. Do the TS-A878 fit in the front dash w/o any modifications. I pulled the passenger side on my '93. The outer mounting holes are spaced 4 3/4" and the inner are roughly 3", which don't seem to match the specs for the A878. I can think of various ways to make them work, but they all require modifying the OEM bracket. Want to make sure I'm not missing something.Front doors: Pioneer TS-G1644R
I think I clipped those ears of the stock speaker and screwed the Pioneer speaker to them. That, or something very similar to that. They’ve held for 10years.Thanks for posting these part numbers. Do the TS-A878 fit in the front dash w/o any modifications. I pulled the passenger side on my '93. The outer mounting holes are spaced 4 3/4" and the inner are roughly 3", which don't seem to match the specs for the A878. I can think of various ways to make them work, but they all require modifying the OEM bracket. Want to make sure I'm not missing something.
