Weird Turn Signal/Lighting Behavior
Texas
While in the middle of the drive back to TX from CO my right side turn signals (all exterior and dash indicator) turned themselves on, even though the turn signal stalk is still in the off position. But they don't flash, it's a solid steady on. My HIDs had been acting up the last few months, and assumed it was related to the HID relay harness as well, but after I swapped relay harness the HIDs are working perfectly again, but the turn signals still are not. Just to be safe, I disconnected all the HID stuff and the problem persisted. After playing around with the lights, I found:
While headlights are off, both sides flash as normal, however the dash lights dim in sync with the right turn signal flashing.
While the headlights are on (auto on or manual on), left side works fine, and the right side stays solidly illuminated, I can also hear the blinker relay clicking fast as if a bulb is out when the right side is activated.
None of the exterior lights seem to be out, fuses look fine, and I swapped the blinker relay with a new one which didn't fix anything either. I made sure the ground on the main battery is good and clean (second battery looks fine too, nothing is actually on it right now though). Searching hasn't found me much on this topic sadly. I'm still wondering if it is a bad ground somewhere, but have no idea where else to look. I suspect this started in the middle of a downpour somewhere in the TX panhandle, as it first occurred some time during the the day, and there's no reason my lights would have been on otherwise (since the right side turn signals only illuminate when the lights are on, I wouldn't have noticed this is the lights were off). It's not like the car is new to bad weather though, so this may have just been a coincidence.
Check and clean your trailer wiring connector in the back.
Oh yeah, forgot to say I removed the the trailer harness adapter as well.
Did this happen after the removal? Did you insulate it well? Both me and my cousin (owns a montero) experienced same crazy park/blinker issues. It was all at that trailer wiring.
Do you notice any water on the foot well? Any leaky sunroof on to the fuse box? Any new wiring you did?
I removed the trailer harness after searching to see if anyone else had this issue, a few had similar issues that were caused by it.
Haven't noticed any water anywhere, and haven't done anything new with the wiring.
Anyone with any other ideas on this? I noticed with my lights off, it's not just the dash/center console lights that flash with my right turn signal, but my brake lights do too. Tried disconnecting both rear lights, but that didn't solve anything. Inspected the wiring on the steering column, and it looked fine.
I'm not sure if it's related, but my AC also blows hot air unless it is set to max cold, thinking this might just be the cabin temp sensor though.
I did find this wire cut underneath at the rear of the car, not sure what it was for, but unless someone cut it while I was going 80 on the highway (when the problem first appeared) I'm skeptical it's the issue.
I'll check on that wire.
try removing both rear light housings wire plugs from the factory wire harness. Also remove the trailer wire connectors from the factory wire harness.
AC may be a separate issue.
Have you checked the junction block on driver side engine compartment for water or wires disconnected? I had my lights (driving, turn, brake, interior, etc) turning on randomly while the truck was turned off. My culprit was water from the windshield was flowing into the junction box driver side. PO had replaced windshield incorrectly hence water was diverted towards the junction block.
I disconnected the harness for both outside rear light assemblies (didn't touch the ones on the tailgate though).
Removing the trailer harness was one of the first things I did, that was one of the few solutions I was able to find other had.
I've been in there looking for possibly bad fuses, and didn't notice anything, but I'll double check.
Try removing the lights on tail gate too.
May be the wire at the hinge is shorting out?
Try disconnecti g front headlights, marker and blinker lighta from the factory harness. Then turn on the turn signals and check what that does to parking lights
