I agree, might be handy for chasing threads thoughI wouldn't use something that ratches when I cut threads. When cutting threads I always only advance an additional 1/4 to 1/2 turn at a time, backing off a full turn with each cut. Always ended up with perfectly clean threads and no damage to the tap or die.
Cutting oil helps too![]()
Check with a machinist supply place, I'm pretty sure they sell a dei set with removable handles and a ratchet mechanism.In a perfect setting that would be the case but most of the time when I using one I have crap in the way and makes it a pain to unlock the die or tap and a tap gives you only a 90 degree choice. This you could ratchet it in a very tight space. Would be nice though if you could remove the handles.
It was an april fools joke on another forum. But how cool would this be? I cannot see that Co2 lasting very long but still. Would be really nice to have if it actually worked. Info on it was in this page.
Amp Hours would be the issue. Also if you discharge a small battery fast it tends to explode or at least get really hot.Interesting! I know folks who have welded with 12 volt batteries have been surprised at how little juice welding takes, so the battery life might not be that much of an issue. And voltage wouldn't be bad, you can weld with two 12 volt batteries (24 volts) so 18 volts wouldn't be that much less.
Amperage would likely be your issue, but if you were welding very small projects......
Probably not going to be much use for a trail fix though..............
Too bad its not metric.......![]()
