PO of my 87 60 had installed a purolator fuel pressure regulator on the pressure side of the fuel pump leading to the carb....last night the thing was leaking so badly that when I returned home the engine compartment was begining to smoke from pre-ignited fuel......I was lucky to say the least....checked it out today and as soon as the engine cranked up...fuel was dumping out of the regulator like a watering can. I removed it and found out that my local parts place doesn't even think that they exist anymore. here are my questions:
1. what is the standard PSI for a OEM fuel pump.
2. Do I need to place a regulator in order for the carb to be "safe"....truck runs great...power....idle....a little rich now will need to lean it out a bit (probably just use a VAC gauge)
3. My fuel pump is working great....but should I bypass it and install an electric pusher pump that puts out about 3-5 psi?
4. Has anyone done this install and is it a pain in the rear or easy to do?
5. Should I just drive it and let the dice roll?
Your opinions?
Your opinions?
