weak-link's 60 bulid (4 Viewers)
Nice mutt!
they are next, 3" muffler tubbing
Mmmmm..... 3" exhaust ; P (Don't ask, I'll eventually do a write up)
Question on this one. I thought about bringing the studs closer together for more shock distance and got slapped for it (locally not here). Has it helped? Whats the difference?
I drilled 3 sets of holes in that shock-mount-bar-thing. in that picture they are in the middle of the three holes. so far no complants. yeah the back end sways a bit, but nothing a sprung over wagon should'nt do. I'm looking for another set off tj bumps for the rear.
do it the way you want, think outside of the box and get out on the trail.
Thanks, and don't worry I get out on the trail (when its on the rubber).
Still got some bugs to work out in the trans, nothing big just a tweak here and there. I was sweating bullets coming down until we pulled over and played with it abit.
I still gotta find the right brake lines for the rear. I haven't had rear brakes for three months :D makes for a fun drive everyday
-6 is 3/8. I believe -3 is 3/16 (I think)
You might check with a parts store Because I think the Explorers used a banjo from the factory. Then again, by the time you get the brass block from the line with the Banjo coming off the caliper, you might be right back where you are now.
Pull the caliper fitting you have not and see if Western has that fitting but in a 45 or a 90.
Not yet, I here they have some really tall curbs at the Mall across town. I'll go run their curbs and report back.
Just got back from running Dusy, good time. Not a single problem(except I kept burping the front tires until flat). walked the trail with no worries. used 15gal of fuel(shaver-courtright-kaiser-fresno). busted a fender marker lens on a branch, but that was the only damage I took.
Tim whats your frame to ground measure out to?
LOOKIN GOD looks like you've had a lot of fun with her lately too:grinpimp:
