Markuson
I mostly wanted something secure in case of a sudden stop or accident or rollover situation there’s isn’t a lot of water weight flying around the cab. Plus I get my water from a spring I’ve drank from since I was a child and I’m kind of a water snob for it. View attachment 1898590View attachment 1898591
Quick suggestion on your water faucet opener lever...
Loosen it and adjust the OFF position to be downward instead of what appears to be upward. If up is the OFF position, a bit a cargo moving/falling/shifting onto it could drain your water into your truck before you realize it. That would truly suck...
If you just loosen the screw & make lever-down the off position...that little potential disaster is less likely.
