MERRY CHRISTMAS! - like a couple others here, I am Jewish and tend to have little to do on December 25th, except crave Chinese food.
I aint jewish...but Im about to pickup the phone for chinese!
My '99, of course, doesn't have ATRAC or VSC. I'm in your camp: Let me do the driving!!!!!!!!!
Heck ABS, which I do unfortunately have on my rig, is also a troublemaker. I can ALWAYS stop better and quicker with more control than the ABS does on my '99 regardless of ice, snow, etc. If I would have relied on my ABS on those slick surface occasions instead of my own pedal pumping...my insurance rates would be a boatload higher than they are now.
Maybe its easier to disable ABS...it also would be also nice (IMO) to eliminate the entire ABS circuit as it relates to the brake system!
Mine has an intermitant fault that disables ABS, VSC & ATRAC. When I checked the code it was for the sensor under the centre console. The fault clears itself without me having to do anything more than turn the ignition off & on again. I think you'll have that sensor on a truck that just has ABS so maybe you can put a switch in that circuit to break it so you can disable ABS like that.
I was thinking there could be a way to turn it off. Fortunately it allows me to manually pump the brake pedal when on slick surfaces without the ABS trying to interfere/over-ride me.
I was going to fiddle with this, but just decided to lock the center diff and be done with it. I talked with my wife about it and told her that if road conditions are slippery, just push the magic button.
If your wife doesn't know how to handle a slide when she encounters it, I'd advise she keep the CDL off and let VSC do its job.
Great advice.... she's good to go, though. We've had snowpack all week and have had 47" of snow since Friday. We did some practicing this evening... she doesn't need me or VSC!Coming back into our development, she was on throttle pretty good and had the tail end coming around nicely and was calmly counter-steering. We did some running with VSC on and off and she preferred the center diff locked.
