Stellar job on those MM. That is the way to go with MM in my opinion. Although I wonder, do you expect the poly bushes to wear out fast? I have used a similar style but it uses a Chevy leaf spring bushing, ie vulcanized steel to rubber rather than a poly bushing. Got some mounts to make up myself in the near future, wondering about the poly bushings in terms of life.
I have had the AA mounts in two v8 Cruisers now, a 60 and my current 80. Hate them! Both trucks the AA mounts have a short life and when they start to go they can let the motor move. Both trucks I have had this happen and the fan came into shroud when it moved.
Dig the rest of the build too. Nice job on the trans shifter. Have you decided yet on back up lights? I got a kit from Lokar for back up light switch that mounts to the trans at the shifter linkage. Checked it out, seems like it will work but need to modify the bracket slightly. Have not got around to installing it, no back up lights is starting to bug me too!
Great idea on the porta band, I would not have thought to do that.
Cheers
