I did a little searching and didnt see a complete writeup on this. Its not a trivial task....
You really have to dissasemble the tcase to do this properly. Im doing a rebuild at the same time so I have all gaskets etc.
Here is the parts list from SOR for simplicity.
074-64C-U Internal Hi-Low Shift lever
074-41K Front Shift detent plug
074-43K Front Shift detent spring
074-44K Front Shift detent ball
074-17E-U Front drive engagement shaft
074-45C-U High/Low external lever
You also need a manual trans shift lever assembly.
Im not done with the shifter. I will need to fab some items to make it all work. Ill fill that in later.
A few pics...
differences between high/low shift.
62 on the left, 60 on the right.
A few pics...
