So I’ve been trying to diagnose a rough running cruiser (1993 FZJ80 with 277k miles).
So far I’ve checked, cleaned and replaced the following:
Removed and cleaned the EGR valve and EGR vacuum solenoid. Both are in working order and flowing freely now.
Replaced the PCV valve and grommet.
Replaced the PCV hose and valve cover breather hose.
Unhooked the brake booster hose at the top of the intake and blew smoke into the intake. Only saw smoke coming out of the air filter box after a few minutes.
I unhooked the valve cover breather hose and blew smoke into the valve cover and heard air escaping somewhere. I took off the cover for the first three spark plugs and I could hear the air leaking up from around the plug tube seals.
My question now is: could the spark plug tube seals, if all combined, amount to a big enough vacuum leak to cause the engine to run but run poorly??? It idles poorly and has a lack of power under acceleration.
Thanks in advance to whoever may have some insight.
