Vacuum attachment for gauge
Plano texas
Hi, Who has a picture of where they mounted the vacuum hose for a vacuum gauge on the manifold of their fj-62 ? Thanks, Mike
splice into the line for the idle up solenoid that's off the fitting for the brake booster.
Anyone mounted this on the manifold ? Thanks, Mike
T into the 4WD vacuum line on the topside of the intake manifold.
hi mike ,
Everything you need to make Clean Splice into your Vacuum Hoses and Tap into your Manifold Absolute
Vacuum , comes in the NOS OEM TOYOTA Kit Below . The Real UNICORN 🦄 part is the 3mm Yellow Zinc
Plated Vacuum T or Y as one may say . also the 2 separate Pieces of OEM Vacuum Hose as well , please see
photos .
Also Mike ,
if u can find one , This is In No Uncertain words the Best Stand Alone VACUUM Gauge on planet Earth ever made
It's precision Level , Steady and True 1 Motion Needle Sweep back and forth is Kilometers Ahead of Anything
you see in the Summit Raging Catalog today in 2019 . This is at least me 5th , YAZAKI VACUUM Gauge
I have been Rolling with YAZAKI Gauges of all kinds since College in the 1990's and they never get tired it seams
it matches and compliments the Instrument Cluster Gauges , which are ALL made By YAZAKI as you might
already know .
Thanks, I have not seen one of those gauges in years . We had one in a Pontiac GTO. Mike
