You could start with about 8*. Advance until you get spark knock when you drive it and back off a couple of degrees. i wouldn't go much more than 12* base timing though.
I have similar engine but it has HEI.
All of my driving is at 7000' asl and up. I screwed around with AFB jetting, rods and springs and got her leaned out, then tweaked the timing 2 deg at a time until I ended up at 13 btdc at idle.
Make sure your centrifugal advance and vaccuum adv is OK.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
