- Thread starter
- #41
An the fuel is new as well as the filter.The plugs are fairly new DENSO. I pulled them the other day and gapped them and they looked ok, not wet or oily but kind of light in color.
As everyone else has already said, plug the two small vacuum lines to the advance mechanism when you set timing.
Advancing your timing a bit should increase the idle speed some.might smooth it out some. Give it a try
Will do. ThanksConversely, If you have to retard the timing to get to the mark, you can bump up the idle a bit. Once you have the timing set. attach the vacuum lines and it should run better. Then adjust the idle and carb.
My phone keyboard sucks!! I meant Carburetor!!I'm wondering bif there is a problem with the carnival? Can't seem to get it to smooth out. The exhaust is steady but has a continuous sputter/miss and not constantly the same. Made a video with the sound but it says I'm not allowed to add videos!?
My phone keyboard sucks!! I meant Carburetor!!![]()
Have a couple of b-52 guys that have J3 cubs as their other car. One is painted olive with Normandy strips. Pretty coolMy BIL did hydraulics on the B58 Hustler. Myself I learned to fly a J3 cub. Worked on Hiller and Bell 47 and Jet Rangers. My fav was the PW R-985 in the Stearman crop dusters. Nothing beats the roar of a round motor.
