Using a Motive Power Bleeder to bleed brakes? (3 Viewers)
Circling back, I also use the BA10 Toyota adapter.
another option that works for me.
ARES 18003-43mm Master Cylinder Adapter - for Use with Toyota and Lexus Master Cylinders - Use with Brake Fluid Bleeders​
Amazon product ASIN B07JPJSBKW
thanks man, cheaper than power probe and amazon delivers it to oz. our market is tiny compared to the States
It sounds ridiculous but like at least 25% of the reason I moved back to the US was amazon.
When you guys are referring to Techstream, are you guys paying $1,600 for it?
Chris
No, generally we run cracked versions available on eBay.
One important note about that.. if you go that route there are two broad adapter versions available. One is called MiniVCI and while basic functions like code read and reset should work, no one seems to be able to get functions like Live Data or TPMS programming to run. The other broad category is VCX Nano, which is a bit more expensive (though still affordable considering the capabilities it grants) but those functions have worked well for many of us.
Also note that this software will trip malware alerts on your computer but it does appear to be harmless, just a part of how the key reset software works. Considering that many of us choose to run it on an older computer we don’t care as much about.
