Updated FSM link
Richmond, VA
It seems the FSM link is down. Does anyone know of a working one?
I'm putting a lift on my truck and need the torque specs for the suspension components.
Thanks you! Lower control arm mounts to the bottom of the knuckle, upper ball joint to knuckle, sway bar attachment points, Tie Rod end ball joint, Lower ball joint to control arm. Camber/caster bolts on the lower control arm. I appreciate your help..putting it together now
Let me know if I missed anything.
Excellent, if you have the tie rod end and the upper ball joint, that would help too.
Post updated, that should be everything.
Is there a chance I could bug you for a torque spec on the joint that connects the rear sway bar to the KDDS valve please? It seems that is the only critical torque value on the rear suspension. Thank you
For posterity...
If you need a digital FSM (either online website or PDF) for any USA LC/LX model 1990-2018 or Australia/China/Europe/GCC version LC/LX 100/200-series PM me. It's bootable, so you can use it on Mac, old Windows, or pretty much any Intel PC.
No cost, you just need to a 64GB USB key/drive to put it on.
For posterity...
PM sent...
PM sent and thank you
For posterity...
I'd appreciate a digital FSM for a 2013 Cruiser, North American Market, please.
Thanks much.
Steve
