- Thread starter
- #301
lol. The manual from Toyota literally specs 5W30 everywhere but in the US.Why should i trust anything on the 15 pages of this thread vs the Toyota engineers' recommendations?
Blind trust is dangerous.
Because the Toyota engineers already specified the heavier weight oils as used in ROW specs, but were then asked to compromise to improve fuel economy. Management probably posed this question to them, "how thin can we really go and most probably not run into lubrication issues". This was then studies, probability of failures which had already been calculated were re-reviewed along with the statisticians and accountants assessing the tradeoff versus increased warranty expenses. I would rather use a bit more gas and change me odds of engine longitivtiy to 99.9% vs 98%Why should i trust anything on the 15 pages of this thread vs the Toyota engineers' recommendations?
For same engine? (Honest question- not challenging or disagreeing) thanks for the info.lol. The manual from Toyota literally specs 5W30 everywhere but in the US.
Literally read the first sentence of the first post.For same engine? (Honest question- not challenging or disagreeing) thanks for the info.
Literally thanksLiterally read the first sentence of the first post.
So you're going to threadcrap this thread about making a modification to stock, but fully accept relocating your KDSS (which the same Toyota engineers designed) in the thread below?
No one is questioning Toyota engineers...this is a forum of enthusiasts sharing their collective knowledge and ideas. Move on if you don't have something more productive to contribute.
KDSS Delete
⚠️Trigger Warning⚠️ I have decided to relocate my KDSS system to the classifieds section or the scrap yard. Ok, so it’s actually a KDSS delete. And because I’m a good, old fashioned forum “pretend-gineer,” I'm sticking with mostly Toyota factory parts and components which, more or less...forum.ih8mud.com
Where are the KDSS failures you speak of (outside of seized adjustment valves)?Wasn't trying to threadcrap. Didn't realize nonUS manuals recommended 5w-30.
As far as KDSS, yes, removing a troublesome system to mitigate and to improve reliability is my goal.
And asking questions is the most effective way to contribute. Take a chill pill and go decaf.
yes. that. can't un-seize mine. dang rust.Where are the KDSS failures you speak of (outside of seized adjustment valves)?
Completely reasonable point.
Too many here are simply switching viscosities without reason other than "more better". Without a sound reason, such changes may do more harm than good.
The major factor here that there is too little discussion on is prevailing ambient temperature and operating use case of the vehicle. That is what drives oil viscosities, to arrive at the optimal viscosities/pressure for operating temps of the engine.
For those in hotter southern states, closer to lattitudes of the middle east, that could be a compelling reason. But those in North America, in northern states with lower temperatures, but definitely so in winter are doing more harm than good with unnecessarily high oil pressure that results in lost MPG, HP, wear and tear on o-rings and engine seals.
And then there those going for further "goodness" of 5W-40?!?? Sure, maybe racing in the middle east.
In that letter, they mention oil changes can now be extended to 10,000 miles under normal use. I don't know about anyone else here, but that is not recommended in my book at all and if you watch CarCareNut's video about it, he also mentions in his engine overhaul experience that it is a bad idea and will eventually lead to oil consumption issues.Here is a Toyota letter from 2010
