Hi Guys,
I'm at my wit's end. I have tried what seems like everything trying to chase down why this is knocking / pinging / detonating (using all the terms for the searching folks in the future
) and I just cannot get it to stop.
Details:
Details:
- '84 FJ60 - 2F rebuilt a little less than 30,000 miles ago by a shop, though finer attention to detail was not paid (he re-used a possible 258k mile fuel pump and it promptly broke the arm off 30 miles into the rebuild -- I was wondering why a brand new rebuild was leaking so badly from the valve cover and I found a 4 cylinder gasket under there).
- Pretty sure pistons are 0.040 over and IIRC the head was milled as well. I would assume the block was also if the head was done, but see above.
- Engine is completely de-smogged.
- The only lines running to the intake are the PCV and brake booster. No vacuum leaks stemming from these. I even changed out the old PCV line just in case.
- Speaking of vacuum leaks - I cannot find a single one. I sprayed brake clean all around the base of the carburetor and around the intake and couldn't find a leak.
- Just switched to a City Racer vac advance skinny-cap distributor to try and rid myself of the EGR curve.
- I can get the knocking to *mostly* stop with timing around 0 degrees, but then the truck runs like garbage, as you would expect.
- Vac advance not hooked up.
- Running a City Racer Fuji Carb.
- Spark plugs (NGK 5 heat rating) came out white and crusty.
- Bumped up (down) to 7 heat rating with no change.
- Ordered an amazon jet kit that goes up to 240 to try and get rid of the apparently lean running condition-- Installed the 240 on the primary after 200 still knocked -- it is so rich on revs that it smokes and I am still knocking with timing directly in between the line the BB.
- Ran Sea Foam this weekend to try and get rid of any carbon deposits.
- Exhaust (including the manifold) is swiss cheese. It for sure leaks at the union from the 1-2 curve and at the manifold-tail pipe gasket.
- Refer to above where I couldn't find any intake manifold leaks.
- This happens even with 93 octane.
- Temp gun on the thermostat housing shows 180-190F.
