Unobtainium (12 Viewers)
Jack handle clips for '74+ FJ-40s are unobtainium.
Yes, but I bet they could be fabbed pretty easily..............
I think this has been discussed before but shaping the spring steel is the biggest problem. I can't remember who was going to try and make them but that seems to be the challenge.
Has anyone mentioned rear heater cores yet? I just looked around, the prices on good cores are getting pretty nuts. I know they still pop up new, and some can be repaired, but I figured I'd add it to the list, and see what others have been doing.
The closest I have found to oem rear heater cores are ones that the Brit stuff run... made by clayton
The heater line inlet and outlet is wrong ... but... the core is circular
Late 40's 50's chevys also had the circular heater cores ... rounds but air travels the wrong way on them
Both you can get the cores ... but... expensive
yup, the Mega used a ton of leftover bits from lots of models(mostly 80 series), I was pretty shocked to see the AC controller though.
Mega used them ... must be where u found that
One off item, or are the Fenders going to be regular stock?
Thanks
