- Thread starter
- #21
OK. I will replace and give that a try. I have a power bleeder but it just does not work too well with the LX.
Why would a larger piston be any better? It'd just require more force at the pedal for the same clamping force at the caliper. Stock MC works great when it isn't leaking.
Sounds fair.. but, leaks are more likely at other fittings. The MC uses the short fittings, so a long one will fit there without bottoming out. My issue was in one of the steel elbows further along the braking system. I put one of the short fitting lines that went from the MC to the ABS module into the steel elbow and that is where I had a leak.
Either way.. if it were a leaking line/fitting you'd see brake fluid dripping somewhere. If you aren't losing any fluid it strongly suggests master cylinder, as there is a second seal on the shaft and this often keeps the fluid within the MC bore when you release pressure. Usually if a cylinder is leaking it doesn't have the ability to push the fluid back past the seal when you release.. so the fluid will be visible on the brake and level will drop in the reservoir.
Got the BeckArnley from Amazon and it is AISIN (cast in the body)...hope to install today.
Wish the reservoir had a screw top like German cars. I bought a pressure bleeder years ago that screwed on and used a few pounds of air pressure to push the fluid through. Works perfect. I now have to use a vacuum bleeder that just sucks air around the bleeder so hard to tell if any air left in the line.
Anyone know the part number for this?
Maybe 90313-93003
AgreedGet OEM brake lines.
To add - Clamp off the lines to the calipers and then hit the brakes. If this firms up the pedal you know its the calipers, you can unclamp each individually until the pedal drop returns to find the culprit.
