TWT -- The Wrenching Thread (47 Viewers)
In the 60 series forum, I've been preaching for a while that an 80 series box can be bolted onto a 60, yet I had not done it yet. Picked up an 80 box from @mel lowe at the Relic Run and am just now putting it on.
80 series box on the left, 60 series box on the right (no, I don't have that mixed up, yes, my 60 series box has an 80 series pitman arm on it). The 80 series box is about 1" longer towards the firewall and about 1/4" taller towards the hood, but she fits in the 60 just fine. It's hard to tell, but the 80 series box has a larger power piston, meaning it provides better steering assist.
pNhMvk5YBQ0TOQyd_zl2AWJLS46ZRlgv-4XTyDvPndVo-8TnFQJRcgKj28nqbQSAdkiO40apC9UD7klLTB-33hfxYTFS8vAzwlpGUXLG4t_orOj-OAEF8Phpim7deBzlQXjvTSbhGy-0WOJZGmbltu450S9BlomZcpFkDG0NbuE9PilPJ78-zSlg2XeCR_4oFWPmqbk2O-utdeNxj5ovRCYKi-dywaXcgiVEDDBU7HbW29AUYlRfGUdSGsKbgyAz9dpRYnzO_6SqQ4gYcWf4VaIro07limwGA9AytJZtXlti60oiRtC8u_jrUgiNCuMhYzOFmty1U68cNMuGIiHDn0RF9JV0XQgX0rsGxOM_fEOtA0XrB-HJflaRXnpgXneqsZ_fjZSP-iJZ1gh6T2bz9m--5n7_IMxp2dI7qtETd8kl4le5lNGQ37uuBUN9nJ5mUucdjb7Lx52SPpcYIXZ48qOsYfQSoSGDQn3LCDNtG2tU6Vtfm1sOTwUazG4elwXKnbTNu-hNUF-q63r0Al4XGFxtcyRC5dqqs7IAQMDNJ-FPBtqKr__5L6evaEJ6E8W-pli73pG3b0GkN8hdR-8uI8si5wcrDH59dlk-VI4DcdwxFIVFag=w2706-h2009-no
60 series box detail:
MPTG1d0x4RlUpHC1gMIoRr0FDJHHdBeNPl9O_eKkblqQit79FnZExeD1905SEIVHHwrUGycZjQjNbxwHcblx-cxWLFoMhTbbmg86ljN2Yd1Xv7TT7WZIOiYdjwhs87xk4nujfFoswgH9ZuzuOAxyg_rR96UJwNt3-zNJeuHOfhVKUuh6YRLYEjE2A5enGKIAvxGAEru0MWR6cXw2UdE8xRu06JFVbECwYUn2hV30XFT5PrtnkGTDWXHFJPPfd3bSV22d8iIIOm2OjMg1dPEFYxQzyFhjo_PmpuOxkYpuTNZe8h91GfV68H4I2B5BCxJS6QMvD6R_0CrXjet9JBR-UdSOD3ADVJJKqaDgy3wPs9yL-qQRyghfe8XeHUlBzhABICzrKVJtoorfjoVHKguk6z5yHtinTFioEdVxOX5nI50WDm0C2N0RWKXdayrdYgFnvfYOVxaTIU-X7z-rZz2Rnqf5o4j6GRK0sDwgCTVupzfEKnRvris2Trz1yojzl65Pp1r7gCdqhKo5vd2_oEtp8w7argBNvMx1t3dU4Ge06QJai8JwbgmskIHMYJA28mEOZiejRmpAQofxGFYinoBTXWMJEcVOhxtuUGyxzcbch5TSJ-LhDQ=w2706-h2009-no
80 series box detail:
bWEdWweHymP03xWe1qGgKKR19ebL0dH2rNxbwMPaxyUBqgR1nf8CssHfigC2XQpexEk0lX6BkrVShzM-S3_v6A6Qpm0_AqREFWYMI4G4pTbpl3EGmqbMGwRPwoJ3xvNknVPiF7KRtubaAkzre_NbxJ-Cf3Jd0bdoR9SSoJg3nk-bij9kMPDyFbcrVJ2WaXjVEsVL-v9SU9rP3D-Mfs_7Nhx_IyW2zcgzziVEDv1N2ERYO2mNwG2jVZygdPOiW4KgvI-TnypI1bSHgHJZAiZkSKvIp-qUw0MnUZbdMWw5U2CjanY1Ce3rG5BCqk7eLcI8ySYwOPAdmGyjawgssKULYIxmFdMsUwZRByW39vDuWhMp4BrtE1iMRioa0SyD6sf6kjCniIsQxwLX3Qa2TkacHKtVCLegRPnD45UK2O4TWIK68v15yjstivpuKelAeTMkZSK_c33OPbUlGjH-QHMufuA8iL82L-CWUE1CVZR49CCJd92wKa3cwi5qVeyHeyFvrFqKfBW2xJ6bs-rgAjvf9PfASB4X0yAM55KFyADqPTVLwDnJtq9j6QJhH1QnGlNkZWJBQAtmqF6Rn6peAEpW9isfg9Cfd8929NHIPhvEJx7IWYCekQ=w2706-h2009-no
Now when installing, you need to make sure to install the steering shaft before the box gets bolted in or else there isn't enough room in the steering shaft to collapse far enough to get it on:. Also, you need to pry up on the fender a little bit to let the box rotate in:
iC0Uo4kbw-xaCpeoVgp8FZBwRhOFPrzg6iW4j5-WQy4pGWJzfnP__vOgKBi-8p2JqCeOLroFMkNN6GrgwP15BmL8Sy6Pr_A8tLXaBaVeq_0EuwnSaK_k_hphVU2UHrhm6L02sLsC1SaJZWKl4akfjjyfX8BnmCbW9tc3AU0vuhpvMsWibNcqozkot-ntZvN1yypUzQyumBSZbuIPxQdl2Mrqb-NFgeBEn0hFkGG5pNClB5hMbZJVAHcbxQsNZ3NrmybbWrCC95nk3R4I5ztpmpWs_0w4_93OU0hLeBSX__IysBb-PyZbBRW-8RV4kPz86cAt4kALyx5Qy4y9xaBzd7ZmoSqyxTAV4yXda0kMN2D0qIsPMxYyrsrJL8TmuWukSMltj0Tg0zSaB3OYCEExiu8ZdraKzOpNGGoA8f39cVrmPo99vE5vZXisSUhsGzgP-b72kkb7B55e5HqN7XB7VQILVsP34RiYhxvnUYyaltNlL4nG05cbz03s95ecIugLbuBCvCBg8CtCclsE_4FFUFREkvZukrnOtVItkeGqjotRi8zluTq6lyoR365s-HRms1WUOvWDgbehE8gpsXUExhb2qoHFtQ7cDVfKWErqrIeIWYRwKQ=w2706-h2009-no
And there you have it. You can see that the bolts on top of the box straddle the lip of the fender. It's tight, but she fits without touching.
_uMzlOBVHE4h-lWcw2dxrIPi-KE7F0TK2_bnEbVH58YvAWgtaWGzAj6qIZOlYoMxQqmoYwdVrYzqikDJ9WECC7HLyPjV3igcpkLoRf9yHpvLnfiv7qTOFVKpspXYbSPUIIogo6Q6r3y3A3tm-JmahwWE3Y1vKPrsrENqRRywQGZjkp6rD_Mx8Y_0KTw54lF0UzD60mrGrMv5Z_oUuX4xh1vTX8kO0lUKa_ZVB7rpi4C4QJhVYoW6BtSsZSAaI_HdCeKYTS0MeoVRWLAbfhIz8deRQow-VByiqS5sA5q7tb_gN2xOJq8ew50XfdX1fHXjxQ1y2zgVhGEI51cPdvqoysjzHFAVTNiecwJSacMaO_-iakqdvQPYRyiNBwdmQvXe2guYaJbBUUwGP8-U__xQqQB8TzomsrHp5AE85TRG8K-ptUsGMRlNynDZxK5D8NV0M9OnxVfzMC5ibXmTGx5kYIOPig2d7WUQAtkXfMW10JUZwYRfpB_W_Qi-LjoYgDHt-UEKtVvNTSJ8LDHlwEguRea1jONm6YOKuYNNPyiG5Pfhoke928vBT4JFs-Zd7xKGbU_1cDI801GWYiclTHzR_gmUdipUR5pUKHjgCa9DrMV0M5mVZw=w2679-h2009-no
Next up, ream new pitman arm, MC/prop valve replacement, hydroboost replacement, maybe run a new front brake line, install PS cooler, bleed brakes and steering system, then this round is over. Got some things in the works to get moonshine some more traction aiding devices this fall :D
Going to upgrade to the 105 series shaft for those big meats?
Money frees up? A concept I am unfamiliar with ;)
@jfz80 , @Rice, or someone with a welder. I may need a nut welded on my belt idler bolt that goes thru the oil pump case. That stupid thing is frozen, and rounded over (even with a 6 point socket).....of course that is the seal that is leakin (did manage to get the crank seal done today). Have a bolt extractor kit en route from amazon. Noone had a 14mm extractor in stock (or at least they didnt wanna sell one).
What a frustrating day. Started out attemptin to swap the ac clutch with one Rice had off his donor. Turns out my compressor is shot, because when the bearing grenaded, it broke the end of the sleeve that the clutch and pulley ride on. Since i need to crack it open, i ordered a new denso compressor, dryer, and expansion valve from rockauto, should be here wed.
Got plans for this weekend, so ill just still let my 80 series think its some sort of harley davidson, and mark its turf
Can do. Sunday? Will be at the lake Monday.
Gimme a time, and I'll be there, Rice
found this on the passenger side of my 4runner
Broken 22re/3rz jerry rigged motor mount. Welded it back up and prayed all 6 holes still lined up, and they did, somehow.
Oh snap.
Mad props to @Rice, who welded on a nut to my idler pulley this morning. We were able to get the idler out, even with a side trip to rescue Travis Pastrana Jr after a spill on his bike ride. Got me on my way back home in less than an hour. Thanks, Rice!!!
Got home and got everything back apart and knocked out the oil pump gasket. Did it as soon as I got home, and took advantage of the heat in the engine. I used a set of milwaukee #3 phillips impact bits in my milwaukee 18 volt 1/4 drive impact gun. Cleaned the screw heads with a pick, then smacked the bit in with a ball peen hammer. 6 of the 7 screws came out easily, the last one offered a bit of a fight, but it backed out eventually. My oil pump gasket came out in 7 pieces. Had it all buttoned up in about an hour, spent another $5.00 at the car wash place pressure washing all the residual oil off, and it was dry in the driveway.
Moved on to the GX470, swapped out the low beams with Phillips h9 bulbs, and the fog lights with Phillips extra vision h3 bulbs. Hit the lenses with some scratch x polish and some polish. cant wait to get it out after dark to see the improvement.
Lots of work this week and I'm not done yet!!!
Drill press and drill press vice were purchased specifically for this job; reaming out the J8x pitman arm to the correct taper for Chevy ends. Glorious drill press.
-MLzzR07wgSqDpPyj3E8vK0WgxZxi6k3Ls_pEJV-qrAoSZedIuYxVkTOo5WCjopMF0CFu6-wvLoK_07AtH_Vbkj8GHafrXPQ_nI2HQCofIPRE-b8hjGw_Xrh0KO_UYqp3atP0nWMEyErT4f5-h5lAOdcdjqL6qe0vPd06Tdq5eAk2qfZh6PkzIt157KYtySRKSaHJStXDsWA7y74wRfnefA9NYBdpTXFURISWzs9o88yKRwyUjq-V3JMlv2bcQVwbhxsWYG3gdLJv8fkaglWQ1p1tMVu0FHxflPZf_a49dEDbm-kFvveFXzKm14VU1AqUmHnHcCDfaPbQRvSF4UIr1DKEaJRMlcIS2N5sUSr0VunGEpUJ01fc2iLdzPHZzHuTfX8MDyIztu_owKPtsF-hhfP8NgcpNfH2h8xnoIsqVWt5NMm10ii9qX_tp_o5pqmdDshcjbUXIsG9ssAIkJSei4qbSLcGeHCiPStbGWq-jVYXSAQbVjh5FThAQMzHhuQHjf42pe8L7JLD15m9sPqHjFlJ7yVFHXQuGTxgQ1s-Qe2Jk-QVDOkw1W6yl43Ussbk18SShclH7YZ-V_dYX4OXlsTGa_oUY19bFB3UxA331zymrk4GA=w1128-h838-no
F0DdsWAgO7rJlTjGs_x9f4mbuEn112eDYhCcdYXyO9kMEXD1uQnEFBJz1FMWYi4Wugc8fOOQNc1LSunSmnU1golXCoAX8SP2cqs8YPz0rof5BtCbjDCRIqNjlUH5r7Ip0C80rRQCVTTFVyOHpTsMKHYU_9-_bpGfQohoxq4azaSPQlzZoqLM44gxDYq1ChOoM4R9yASYTzIF9rsfatc7f2a1Vtxax3GQ-clRuTtKGNK7nBQQlaMTl7LlBNzmwZYo0f1QrhW9PTIg8N-FiLoXuAAHk3BbMjVoDsHPIx5Ui1QcUDtoVmwN-vs6ymS9Oy1dAfW3SSulpN2piueAc3V1Fi5-J3fQswADkGptPf9jFyxXIz4-MJk5dHGUry14IyD39TJC_UPSZPoqlJHNlHoh58bMq8BkWPm7lbrN1M9W9pgZZyFBMMai0_ire5IndFLrbDoFJpjgEuPDrLCZ0RDUeW4KfBoruaP_35pRGXL_Nc7lK0whi0v3MkJ97GkRH15rFd4NtwjBVJQNuGapsO4VsFyzBogYn7QflAq705nD7p6AZngN02aTWBsxEpLSQopVPatNUAWtmmMotMrq3kMLyw9Wf_Ps2BZZBzET5x81lvsqbr7AIg=w1128-h838-no
Power steering cooler. This is a random transmission cooler from Amazon, fastened to the AC condenser. Remember kids, wear protection.
5Pr_a266wQucI3rJVSYdQHh5SveMHMNDiiX76npzakCEjZfG0kYmH4aFIrRwWN1178ImAnyvbw8kzbzU_3x_amXKxUFujpXfYQVbzNcL2sZ0RbUa7q7BomXhPFFdsdks0vQXL0gyJtBBoeMImuZh0C7TfQbfMW8v4pcYzWPvW9xu4ppNF81qS71ApchTiTbET5GSZ_9W3iPniN9lV41sFnxbfowyQlAur78kF31bOtLqUwXfPhEiBdxvsMXXXMfDbLBGF8mLpBsLkyM_NbhlOPR0TbOt6G96Tt5uAxbY5dI7gcOSdXvKGL_fuPWr6Rd2om1E0SKoawfUc663X5J19IQ5X4lE0-THv60O_gm1VRmM89G3s3_p8TCsvAOpr7Pucuvd5nbowMzHhJihE7zfxmt4L7hchNLpIsO7JaPxurQsm30NSk4Sy5j5JZq2zt5KseaBSrJxVIdZ0Myb_fO0-qfJF39K518FJXUmenf67b1xvklvXOT-MyL0dIaGZKfXrllAR-GIgWWwUKUEA1sA3misHUBJRjsmk7xpwhzoByAFHeGntnpKnfsQXy2GJGz8rqhLjF8q77hASV9kRKQTgYMeQYtDjMOFp2NdPjOxvsaTwMOcnw=w1128-h838-no
0H6GUKcOuRWgYUgxcK2TtaTgZVe1PFDMetqnaHB1Rg9sEIs0pgFLzROKu8FbwKUVASzKJfF1AeY4pA-pOtQyghX1nhCI-NKRjENX9Gxr8yGPWfBJYrIF6xNVtPjnu2aiyv90SJIP8-hdmVXqZStK7q1CQr1i44t_sHWCOnc0ax8rYF_UGU9OeO-oxyFURLbwUGK87ZyxrkBafU96afkoRDQghLpHJptycFQ2OrgYoaya5j0Pa0MsCTMSP7NJJDF5zzDVZ8kvCvCzv2GPq8MBd3PVLATg_bhHZYI4Z-MAIwMj3_O45NIWUjLkktZjYycpZ_51jyPZ9Zjz2lDv8Q01nMIUT3D7mIttV1UvHkc9fjYDwu7P0Sniyo4A-1jzOZHZ3bBcit-ttRE64zXl-YpaxCEo2G9bXPIrngR4AIpfphcJOHyN--8z6IM7axbF6ACH1zkTuAe83Y13wHCSiX-2trSkL1QA4IE9___N-hOlnBuoHIpYCNRwEhQ8hPvOtZU29o0jCe_fG7VlRgwz6ctjWbg4JV4olW0Cnno5j1yg104g2vgrPAP-FINk27VJCwY6CPHfuLXGnu_cJeMSVJegVMbbm-mRJEQrC_dKFrblzvaS42yRvA=w1128-h838-no
This finishes up the steering work. I filled the cooler by vacuuming the system with my mityvac after filling the PS reservoir. All I've got to do is bleed the brakes.
Moved onto the intake work. Got tripped up because the original plan was to go straight over the valve covers. Unfortunately the flat plate intake has a slightly rectangular bolt pattern (that I didn't notice). Moved over to the 3" intake gear I have that was reserved for the intercooler install, but I was already in this far, soo here we go.
mEOJ47dQWZhwtdRHUROdcy8-9PYhWrPuKA0q1OyfcbJ5tUm9O_HPdcy60lMn0ztpSD7v-4sT4C-TIkhhutdQF0keMtbtLhjEgkWp0CrYgbfb4vozDQFygWYoJyDyHHzvXmSqJQU6rSScPNyhNSafkYnOK7_kA79Icj8uVIeVNpj-2heKFqLPrcQLjR9-_WhNTJrQ3e1kXK_Td8ohWH8-pSR40AsHdcRubjyxhtsdFZCjQgggkJtakY4D5a_CW8p1ivfo6vBPHMw6N8xdGH-4hdy10LwVr3uNSaCFm8uFgI9LCOGcBo679WfcP-7Hpb-rn3Cpt0Z13Jq8DXm-Ppm48VrPawNMDLgCxGs3MDR5HmmRFX3zM-u08eILwEnVhPwJSEKG7ck6bzER0RKwEHfipw_t8T2KvPTrIS7PSX3zewpSf8JS38jhPpL4vQ3vclb5i6TzvjgWD2rKXdGFTi0prQjW5KbPYUFQgDS490cXPFeUX_M5J2CsmzLcxu52ivkkua8HVdCmUVBkAMWtv1G-tQ48h6ezd4Z8DrT4WFn8GPyu9oK1M6Lh66OjLCBpFdwH-2bRzVwkV_j3fEfx9EssIvfS9BTeztffisdkjPgmxoKpqY4YhA=w1128-h838-no
Original plan (didn't work):
lxs-qv9v7HpXtf5C9I7UUg22oQ44UhLYVt3RMvvyLqOgiTnQfa90QP97tTI4fLkaTROwcELm1rES4p3kGRQxqboJGTebKs8UJnYPznYcxKFBdKc6Ot9HEN5fxF7_UetuQg4XA1yHGUyqfwED3KGnXcY9B9FWkwjlHJlC-vEVsxeB-lAVTXf0kq6SQNUC7EhK5SUwri8ssmrW1g6KjT9X5gIGTGsHzhA6CdI_FjRv_v5GnR3-8ILOgOWn63m5SieXfG3dVGpnfXQpp5AmQ6I8bjmP634utBP4YlJ6BZsOdTUMXi6IAlaLNj_8-j4DgKm7Cx2q4688J6V64EvTU8eQGoJFrSDTzHdoIYQH0EkJ8u8-5BjWTQkYqEmPJJYLG_35ttzfF0qU4ifZ_QmyblEws-OpI1dBbJIcsmwVDwxZUcH2vftecmrNXnBamQNME6gVGcsRrbMtqYOYRZaKS9AW64vmhecoTA1bgRG7DHFwkQM-8erhU4Rg6neTCfdLNH_mEqg2ibyXfdEQnN_8_PCmTQdEYA8sf5_rNdC9suS0K86-E0KOkPSF0AlgMoS_l44HENHCdBeOesLHjiRu6dnzHJmICpa06rYC0GuK4hm94HHpO-MgsQ=w1128-h838-no
New plan was to shorten this component to make it fit between the motor and master cylinder:
3S-Td-ujxV7ttlZ6BZuPt2McgIS5xF8LFJIsNZKIwu30eZ72Ku14EZOw1zNl-ZFJjYY9Q3ldD2WNN2vkxwv8DGHMhTQ1Piv8GTnjO1V6MtFRHIXsfkm1hq1-cGSULFr3B1NAqrMqhZta1KcyHCDzxCykLy8Q75gQYOr0MZynkDWiDcaKrJSq5kCIVMA8wcfg0avITb3HqjDI3SXD_A3YggyJWS9ICwqy7NHZb4jbXe_h109105mZM4WdWm_GYcRcqNAbAPsQ0eQgVF7HYh1MeAKun2pTiOEykycH2IUZR7C5PibFG2-Jwe0Q1XpUA3oFFKbnyYwrNOKKhDybqGFJb4vwlbcKKUtOPSbq0kKGLBS518JPC1InLN-6dngZQGR7D_lMhPMqEOCsnw3tOFciSXP3MLbb0PFk7cGGXNavH4vFfJP2ohE_4XCEq7sBTIZkOj1V_-pAtoSUVLGK5yqA5lErp3KyOr_O8PWI-yTC1mr5Af-G4oh1gvfTEvVGANjgzVYTAbFOtSJnTl1msJtZomYDFwSKh-bQh6ePF3DelDWREk6LlEYmctAzSYNE0_1nkYASTDPSu0kD0Vjab9MUW4vH7WR_Y-5a9zxi3NinTKITdKjCAQ=w1128-h838-no
Also changed over the turbo connection to the compressor exhaust outlet elbow from a HX35:
7TRNzX-cM19HNr-xViApakeGwmA06YCG3dVNQ3yKnnCqxtOnXSGlIzLNJQcjOxLZbJISZVtU6NTAoNPyE6HGg2CUg8IaTnuUlVJzVRo13zoAKZ08p23yKsymFAEbDXCgod4Sl85L8-tSlF36PBJPrrw8vvUJz1L608mnwmHEVtgCXpgGEKt_HMaxZI9ZAoZ9gYhmptu-c_6ddyFbJz1HIXpQd_rK6UMFVpExHwM4vIiFHPu5UnG-_UiQFOGyvZRorQa7c26ON-80UEsAhdA96kCPbVwis_Qgr-WtBHCe50XJA2O8rTGWK1_9DgUcFSs4_iVwpawAfnstDF15gL2F3SKKpwCb5Mt6axSWobmbdD7mthkUHwL3ajGd1JsPwTbV6ejGUiqBUaUc5Jyri5IxZx_MNFAbJRPSMrDI-GTLzX0zziqQtqHvRKPdsg680YJc69X-sWtrNdqyET89Js0yA91_OnZzV3poSbJCqbdY2xg_Jo6aHhOpfP4VDum-DQdArmYZidL-N9CfWUG2ps5idfxGYsC6SAJivILEDV6UCnrABgE9CH7bqcQf0_ONt1d8o3Ad5WxrZACEuMUva8kBsKFbK4iWM7Y2_D7zFaUTsxwVvJNhFA=w1116-h837-no
Fab process:
6q2aDv43dy_pqEblu-xZ-fSpma1EKRHPBq2kGhQrDitI7l7U8EntCctbJx37jkhTGFNwLomnAy_s72FmB5VP6x32F6XxpbW2Etup6un9DfTxgvxvarFx0WuBd7pK4Q5HykFB-xB3EoNZncAN1SIKof1JmWIiziCX_qlO9Se3HpyA0hlcrG2AsL2qeaQNE6Ry3RsmGu8fJQI6KORTsScA3F9nYWbfyMMiBpUgjDnCRCTU5kG_BjMsuKxx_ytuOISG1p1JzsMuW8BbLNAzm_fj4TOInCNnzVnuRYf61ZNU3NQFGVfb15QpMUfhY2I0tIl5oALWORS1eyAkkHMKL8CWzSWhtLGfSJJdTQNRZNE9JPJUKHU5G6zHvmtUgvzLpBct4BdLtJb-dTd7easBC2wYFqpR-AbQSbsnJB-UyfYMRvSpKHuAaUHqEVaCOAMdr5tvml0Q2EdJ9UO3D5W0lJkIz06UfBgiqgpgIuGBhCeUuSAq3Ywb8iQUv8rtDkGbVj_ggr7-w18RR9QmrfawULcyEF9WNaZD6_HcO10t-trby5vTklI_4OzScZvwbHHYwaKkWr1BXsX2LtOkkZHOkwOtiv8VPVP4aKjOgXq0z7Rrjlcv0MvSlg=w1128-h838-no
9PJj5LbukJs3kvYGeLkydKNhRjuGy_PCDhSm50srwbc8PSyLcm4I09hJGoWe4DZ2oLPhaYqeK83STBywzsO78PpkEo6-5wpBCTTv9c1KyFzvQex3k9BpH9GT1lombR27j7CkcAYjmVv5t6bA7_7W29iwKEx8tj6E--oYLX8Xkr1JRvp5LT_-WjeGnzHtDt_KATvJYLlF7HXilOFTeft2Fp_FeC69nRiMVLozeg2evAicAWIYtjaHYSAlmuuSABBSNKr0e_XER7NxI_4CeTkaDC806M4IehOiHGgy4J3YS4__Y3xMPSqyNoi4zu7zkGGiAPvsjEqrPvQLeR7wuZeLGSRNGXgogS2XJDZWKICaVoWmC7KZY6W9k4BTU95lJ5-oGwd-RvrzEZemv7y7axckq1iVBm2GPf43xCZxOsc3IlGWH-TMfwPG5iDsdLucwrbk2nynDPXgfT3ZdIP_Ego9Qh7NF1nP6zVHfNepnim8zccrS9uYEJotKZpDRlmMhBWBwziVfFhYu-bHkaAJ15yuIph2OepwFgQ9zuxbkjwp4rqXY6cZDfA1_SxReQQd2j5CSarZhrIzRQTi_8bLoZ3NnF_0lFvUHw338mbl8Gp22gpH7Imp0w=w1128-h838-no
Yeah baby, that'll work just fine:
z6s00ts0I7cBRUKDiMx5fJwt0XLet_SIQJYCd9V70OMbUwaPikDSt4tddhdZG6XtLGTAM5zAY1It4C9NvSZbRWBtlz1wrfN8uPfJ2hYjJ1UTyPhYgE0hrptsL4sCG67DxlLLx9B9VVVvCAAlTQZmUH8OWFm_UQ--qRHEUpHPGVe_TCCxPX0fBykouxs8h90egWUvuRn0gdd27QYobSX33jB7HKO6zjoVhAh1RjipAxEoyS6jp7RzlAyfTEjMvmq_2E5tbXt8HMyrkIh8mDCZJLPqzEW438KOHzq8xNmzuUlhQFN8V8nzbr-XNlB2umeNZJBiT4WBowuB47ABeE1s2dhvwHWxMUaQpgcd9WR8MwzNo4dTPoUURSXxOb49pFjaUsBLERI06J6JuJZ6DZTLhtXwH5IZFJt7tYaSZZgs92MpFNsejeeMmx-5Anf4kQlfI16wnHNlnQno-feysKghBW1-l_upUfQriKX6nkEmm9mbn20wG2m176K_q5kLekdalxgiaj4DGhXRqQj-wI6dpQply5hqXqvmQ0ZHs8DE_6dFEJ2OEACCoWK3FFf5xr7CN1u9aiZBG6mk0BzqmrXXsqd9lIjekk1O2VlcfTHjelCvHOGYPA=w1128-h838-no
Oooh yeah:
PN9_rXoSC-aVvJD65z-J_T8QfqppLBeMR42YmUNE_Qa46x3deKUPqw32pThBrXgLhTNTdBtdzl_K6fi2j0EerNet1BgqQ_6VTVWurAfaDstG-soPBfihMsBcnIp-hdtDYT0hc06oZ6AcYJFSUBZvrVmu7d-NTUz--GsR2xisdTRt79OqStElvtTz_OX8SRPJkFzc8FQGDWBPQ2HsW_LMxWX2PgvjUlxL8s4qnPXSqMtCpqWG5VM5Xc8JsZO40hzIuXD2T_LjqQeC4nlgRVXHnc0giNM-8NYZc1mpseZazFcYM5PKWLpmNshV8kFjEmh4rauFQHPBEGhwAfbWpCovjBfnZB55Ds8QMzIXiygDBRI0ob-CQ6j8ALAnXImHjYfH3tFBgMYTDXzPRUhU3E0lHRAXVMYAqGtlw_jXvmClVCuO4bhfku_3SIFCthRJW3lWSdHDmON8CmXmk7U8bfoJI4da8b179OTnDr_KJyTFgfI9_X8yUc2HGGrV4mGJGtqE7_69XULUHFMdGjLeuF1KcsXDKoXna8Wtm_Y_KW0Ciz1IT2y3jUh04xblasg3FQDJoVTPzFPp4QBJyDFgL9IyoUfMNUULydp0XqupiZxewP45xB235Q=w1116-h837-no
Little TIG action (@Mtbcoach I need to give you your TIG back :lol:)
biv78OT4_J352sCAt5D2BsYnNcvEnbENqaLlXJgUUoWpi8dlTQaO-xUZwsupvV10yYYXYqRyzwDpFefC8p9D9VMxvfFMn0BVCiG68RZlOJnwyyzyDvlLKkCs4nog9Qf2cynJhe5W9nEt-lMk-ZsfXIXhyWtYYrBdeZrMRSDt3jhUWzdW_3KsrXqUpVwMRYqkwxPBK8xd6ULyrGPQpxSnGhrqXvxi8V6CKICHuiVh2QnIYFbihUiKMEaqXAWUOHf2Kac5DJ8mdC0q3HdVZA0Eoz1NL5QS64lbFI_Am2DXT45f6I76tIHFWDxoEKUFcYKzGJjfvUJrBn7QeFWST9VpwPwEBZZkTFnNQLmAxw2AdHk7E7ahBLYH0d7uUTaT-C0hfpLtZrx44FL_WJ6ycIVJcSDN8_fx1r-aPQYKRQJ9jIIZLNZ1Wy1GuMAHhPGJV7hqeJidKXOnY8AWkh0P6aWM6fSJT6XdV_7Uh-pPt7iGZI4Ixbppo89rymeXebrVifgdwakWlwsBBLandOkLSX3iywm99s5md9S8tdV1Ook5IKyPxPOcyE6spUztxYdOXA948VkLlo7uR70gdEFwxsHBSuZdT0oTB-1eG7PeqJheF5MUGz7yTg=w1128-h838-no
P_jMAts9ejzfFrOt4mgHPZ5EkjBjLKjLnfBYriuULkzIrk-coRgkkykFIZNvVZbhqppN7uITtYQh8cY7kn3GeRosI_zYPpUOJEunrWz1sLJz0L4tX04GGes-ZA_ZAss2dy4xhO9qhDabo4Gafs8vxc-iJI1Ljxl61S6roc-frV4X8ihAHBw5V_Am7cP2m0tbi8Qm5iMw4I4Qx8nuOY0jf7IsiINJfya5_RGjf1JhCTi84bM91MI5I-5sqzi3AlNmoNg-KrnFENwKgJ3uVf_2JkkXabreqBeAQ6mpSS51068wpNUQ_3saj4i96EE60eVDbGMhWoIOswjGt2OOxTZ_nPLsGzm9mYg8741KtJ2JI1d_asjjP0W0U09maH0M_wH_gDtsZvhNh-HolxfLLWtM_wAuyRpuCWiG_Zkd1d-nVmJei0_WhDH1HXLgbVfcKRlSYicduekzzhq7k441_W8rgm-_acOnQDrbXNTttiXAZ-58-_0z-TPL_WuoRX4_7_x7OT1qJPa9Fy8AwBNhoSJO18OsdLeFjxOESUvJm7pL0zUjZUTkX6wL9jlg_biwsPDqCeb_2soL7RYJ_RiHgcxpJwy-fUXOfXyaokGrLWpkjKCLeJCMng=w1116-h837-no
Ground smooth, filled inclusions, repeat, after done, smoothed it all out:
BySAxCe9Z41fX7P-qEhXn_g6-BQxFQl-WMnEY5RRuXmfWnw_PXZVRUn0Z_ogp7UNEzjhW5NXBk_5F51_PkHwzNodH7Yg5dg3DxsbvBeQoCqtQhVRYs1OfDzezovIAGbxdG9KTZ5AuqcVra0EwFjoK660XBprhx3PNAR3yWgOdpSvjU1DG-MNJQfUd3iwYCFeVkaslXXUcox_jica2xUz7RGI29LBgnnWkZ8WoI_qcjMteT2lqtYp3ysQQiIiAsIukQ39e3ykpyeCjPZl81TovlImHWZEGO0QeeBZvR4n4hJrGz5OxoCSbkQ_bwA25amttLN1iri603simZBm64hNQvJfuQGKUtMEIvBgNGlfg9jjG-H0zhbD1Hf0AFpr3BJjASi88OygoWoWcIUs5sxFs6sw26zHZ32-HTdJ9T1uggi_NMQM7e7WhQNnKJn9bI0gF_INfpkwfyqA3ytclqIwAkA0r90Nz7jaqm7_gm0eKQMTK4vAk3e2kaLd5482Vt5ortCUyQcX2zyd8EENtxRNxsFNogcrNxis_lsER4HcpiJZXkY8BV3_JB_nVUjXUm7KuK_A3QpxRdWcY_uJqcsy6-BaWgvTRgDwJ0YwXCyFKe_jivnjgQ=w1128-h838-no
xZAjpF7XfTT3fQJ2udVC3xi-K8ljahj_qfF9UDX76GdRVzr_oL8nR2dTR8q4SVi46oECcnhPYQk8dM7Ndu7cqcS3TBSV3o8cq3JctcQYGAdhO_Jw3xkTlgQTgW2EkocfGMvesIphv9VRsmL3-bOVFI7IMNuAIodgYx9xX_TSBBg8nRliucGL3V1dQAFvoAzq0_GoyFarrvQbvDgiskX1q5YzVMe99vhhL9JoyTklql6b-c8etiyTW_OacuvnQJqpL7zU5rO99twnImLPHJGeiVtbOlzcVVsXEGfX6JoiJHuJTM-8k6GVReY2eCMdsfxDoB6yWdz5mqo-RdsYNF12jZAK8CpgOY5NzXp2tLTHXWgqSFb4zqj7Shsgiss7yV0Sg5V6jc_lF5YKHZvo-6DXpJY1cY2zJ0NNyg8oeqKSfAqRpJDLghJW5mDyPscrLy-rc_XtHOBxlb7Z_hmO3Ub0tRpISaIiP_wujj__WtX9uqrCVdzx53_8n4zWbzzehryPMlJkdzyrgm8ovMqfNYKCK_UHcitolKuha8Gi-KqCAm6kOk0QQUq8WSUAtFKl8fxy_06pF4CodlSwJVYlrlBU0qOJg6K1kV2nYJT7BO0RfSlwfsl3gw=w1116-h837-no
Little paint, looks AWESOME:
OkEIlMTvaRzHd9CbUsPxta7EPLsn_O9VchsTk5cMbDbJ6uBYSB_eWjmGIiXLq2fEY4kP9_Y_JKVpr6IFdYrh8JIlaei93jhUm_kiJURf5wpuGVuTvv44xEWyANQFgDULbhz8_UL5Ytok8x2O_k78GHghRIq2So06njZc6pKGHP2ugT0aKpQ7j6Guo7WaKfwtgBg8XltrAa_hirXNncu0ftq6NNlNaMujMuVAn8hmNn_E_xJsEgwRWWwNy4AuYyXllB4DqM7hvEs6atZtkGmFeMn2dX8WlOBTAxiYXkZ4HrtHd9Ns3WvJyr5ylmbGyu3PwT1EwvMITO8j1yF9vA0kOFectf-3dK38LMLR6d5QImreDP5W5tDexlEtXvapup-ICKsQczFV9YVBrS6brWbcMaPTPOFZfum_rDXjhjsTCn6WG0j0aLkf2UQRaoelVPy_Hw8DkoP17iVSJByvolZMCSGk_o8qW7iehR0wKXoA4t3Hl_hMj9FAEnweyWeYKwxSPrzAgLbHcpGHBxD5iWyvnsuk3NHOs6nSJlU5u55Q9IU5YTQyXki4Z3JCX6SxWtHMEb9mHcbI2Lnh5wW_H8IeDH2OFWjOJYEnxuw9VUS99Yl6dPS3nA=w1116-h837-no
EnH3Ju1h46QcmVpDjdy_WU3bB7Do_PDE04R5OJ67nVRBeNYfvKXZMJ-JCfCaJJL1Q4nlufHlW4hzxx_0lGc52XERYi-woVtWTL7iU-ajk03F62D6x4x-kESOXUsKRJjWChrXeHFGzG8lb2TWOGFXlS-1OZwJVPnUSw1GSpVF7yrXAJRR4flBz8u82yNHF5JUUZjv3hyi76JXFEusAp1CD1WZAQ-Gy7Dq1nc5oQAMZBzlNc7L0WUU-FHEAQQrgTip0bxCwpnPruvT1opTD4GxvGcrnkrU3GiJrM_0_dsA0j_TbxrhtLYcc9TwjkNz3-MqmdGN46bGSXUjypRzxMNcwvBaimhWYYxmDWeFDJeooXUx6VhEzMq3XbqKm8R5WE42OQjQY96_JWTRIi7wzj_40Rw_kZ5cbcia9dNILNDnX1lhsubYSthKUBogNTRlJl_agz2TVmPw8F7LeLK85hj1x2hHxyXi5A6hZGx84jz1eYkTN-ZC66pxQvFgzZ1H9bMRvE3jEVdLosEQbexIRNTGNjH2FVGSbKzkZuWQ-odJWs5fJamHMQvsl8cdmnFXZN9-zghFhql_0ZCqzF9anksY-aJw0tRw4cEX4m1Z1xeMPFPbaIcRqA=w1128-h838-no
Time to order some intercooler boots and whatnot, then will be back in action.
^^Wow nice. I wish I would have posted up my transmission cooler for sale last week :)
Here's another hint ...
