Zjohnsonua
Had planned on having it together for the meeting, but my OCD isn't allowing for that.
Probably the original caliperThe 80 had started to pull to the right a little bit a few weeks ago. Pretty close to a wheeling trip actually, so I figured it had whacked some steering part and needed an alignment. Made perfect sense until I went to replace the brake pads before heading to SAS a found the real culprit... passenger side caliper had a stuck piston.
One new caliper, a set of pads, and a brake fluid flush later and she should be right for another long while.
I believe that WS fluid goes bad quickly once humidity is introduced.This teardown came to a screeching halt once I pulled the VB off. I just can't see a reason to progress any further and I'm leaning towards buttoning the thing up and using it as is. The photos speak volumes. As for the clutches...their thicknesses look uniform and healthy. This unit came from a WS fluid truck, so the fluid color isn't scary. No weird fluid odors.
Thoughts?
The v8 swap begins... this will get its own thread eventually. Nice to see this trans start coming apart.
whoa!!! What is this getting put in?!?
Yeeeesssssss! This is a game changer.![]()
ENGINE WIRING 1UZ 2UZ & 3UZ and immobilizer removal services
1UZ, 2UZ and 3UZ Wiring services for engine swaps. Wiring services done on all Lexus V8 Engines. Easy three wires to run the motor. Ignition Start and Fuel. We also give Temperature, Rev Counter, Tacho and Charge light as a standard for your cluster. On 1UZ you will get OBD1 flash code system...forum.ih8mud.com
TL;DR. Dude has a service to make the UZ family as swappable as the LS. 3 wire start up, no immobilizer, reasonable price.
Still have to mount to the existing drive line? Can't mount to the 4spd manual.![]()
