Two piece rear drive shaft?
woytovich
Science...
Metro NY
So I do some significant rock crawling in my FJ60 and the one question that I find myself asking often is: "Is my rear drive shaft clear?"
That said I was wondering if anyone has swapped the relatively long rear shaft for a 2 piece arrangement like you often see in box delivery trucks. That in combo with a significant upward turn of the rear axle, like is done in a spring-over, only moreso, would make for a lot less exposed drive shaft.
Thoughts?
I'm curious. In theory it makes sense. Myself I'd just stick with the 1 piece driveshaft, but to be fair I don't do any crawling, save for going over the occasional downed tree.
Also is the 1 piece in your pic from your 60? Custom job or did you order it from somewhere?
You’d be adding extra angle, more stress on the joint, and also more operating range for the rear part of the shaft. Also you have an H55f/toybox right? So your rear driveshaft should be pretty short already.
Edit : drunk error
That would be interesting. I believe the early Tacoma’s had a similar driveshaft. “Carrier bearing.” Or something like that.
I’m kinda thinking what @cruisermatt is thinking. Would you even have room for that?
I’m not saying no, just wondering how it could work.
The drive shaft pictured is not mine. It's just a grab from the interweb.
I agree that the angle of the joint would be steep. And the amount of work involved might not be worth it. It was mostly a hypothetical question
I guess you could make the first drive shaft section short to keep the angle from being as steep.
Lots of long wheelbase 2wd vehicles have this. Fine for the street with limited travel with the OEM carrier bearings.
You might be interested to look into buggy driveshafts. A lot of those guys run a setup like this up front where they have transmission pan clearance issues. @Mace has a setup like this on the front of his FJ60. I’ve actually looked into this since my front driveshaft is pretty long and hangs down kinda, I also didn’t turn the pinion up when I did my SOA so my front driveshaft might be a bit of a rock magnet. I elected to just see how much it gets smashed before I get crazy with a setup like this.
I don’t think it’s worth the effort and extra set of joints and parasitic loss just for inch of clearance on already short rear driveshaft.
Thoughts?
Here’s what I do. Take a length of 2.5” DOM tubing, good wall like .188”. Cut you driveshaft in half, slide the DOM tubing inside (2.5” should be a good slip fit), and weld the DS back up. Add some plug welds on it too.
Now you have a .250” wall driveline you can slam on rocks without concern.
Yes but for a rear be sure you get it balanced after that!
Not worth balancing. I have a good balanced DS and a trail DS and swap at the trailhead. And I’m fairly certain @woytovich 60 doesn’t see the street at all.
Very little street, although balanced would be nice for trips from campground to wheeling site... or out to get gas...
You won’t notice a unbalanced driveshaft over your TSL’s and beadlocks. Trust me.
