Today I cleaned up the grounds at the front left and rear left lights. I used a grinder w/a wire wheel and dremmel to get everything nice and shiny. The left side blinkers still do NOT flash. All the bulbs light up (one @ the front corner, two @ the rear corner and the dash indicator) and stay lit, but do not flash on/off.
Are there other grounds I can clean up that might help?
Once again, the right side blinkers work fine as do the hazards.
All the bulbs in the circuit do light up. . . I've had all the cover plates off to clean and look at them and none looked burned. By your thinking however, if I swapped all the right side bulbs w/the left side bulbs might that make a difference in at least determining if it's a bulb issue? Actually, the one bulb I haven't looked at is the dash indicator bulb. It does light up, but I haven't inspected the socket or wiring etc...
Tim - awesome diagrams & explanations - thanks for posting that! Now, because I'm not exactly sure what I'm looking at. . . is this the actual turn signal switch itself? I just went and looked at the wires from my switch. There are 4 (G, GY, GB, GO) I know that the turn signal switch and hazard switch are interrelated, but don't have a good understanding how or why except for looking at the diagrams.
Aside from checking all the connections at the switches etc... what should my next step be?
Thanks,
Tom
Sounds like a resistance issue for me.
When you have bulb burned your rate goes up due to lowering resistance. Slow or no flashing leads to having too high resistance.
I think hazards bypassing this resistance.
you can find what is shorted to what by the following diagram...
Thanks,
Tom
