78 40
So all of a sudden my blinkers start acting crazy...
One day, the left blinker would stay on when activated, but not blinking, just ON.
A few days later, both sides are doing this.
So, I've been checking bulbs and fuses so far and have found the following...
lo/hi beams work fine
hazard flashers work fine
running lights work fine
brake lights work fine
reverse lights work fine
All turn signals do not work fine, they just stay on until I push the switch down.
I am thinking maybe there is a solenoid somewhere that might have died?
I found a small gray metal box up near the fuse block that is quite difficult to reach.
Is this the blinker relay/solenoid or is it the seat belt warning buzzer?
There is a larger metal box nearby, too that says emission on it...
Anyone had similar problem care to share the solution?
Thanks in advance!
Thanks in advance!
