Turbo Bracket? (1 Viewer)
In Between Worlds
I just found a turbo badge for the front grill. Will I need to source the whole grill or will the badge fit on my stock US grill?
if you were to post a picture of this badge/decal.... then someone probably could tell you exactly what would work..
Yes, there is a bracket needed for both the Diesel and Turbo badges. I would look to our Canadian sister/brothers to find one.
HTH
I will look for a bracket as well. Hopefully the grills are the same. Can anyone confirm?
Images from the googles..
the grilles are not the same between a 60 and a 61/62, but i don't think that would really stop you from putting a trubo badge on a 60
If the bracket doesn't work, you can always make your own or use this handy little reference: http://thistothat.com/
I found this on one of the parts pages. I don't know what year and trim levels offered the turbo, but I'm sure it is a similar thing. You might be better off making a bracket than trying to buy one. It looks pretty easy.
So do you actually have a turbo installed or are you going to be mis-labeling your truck?
Not at the moment. Little items like this are hard to find when you actually want/need them. Its a preemptive strike I suppose.
Will the diesel badges match up with the US grills?
The grill part number seems to be the same for the FJ, HJ and BJ-60. HJ and BJ will have a Diesel badge. However, I can't find the "turbo" badge on the parts diagrams I'm using on line.
I installed the Diesel badge on my FJ60 after my swap. My grill had the holes and it just screwed right on.
I would check with our Canadian Mud'rs for a diesel 60 that is being parted out.
Thanks!
I used a sign paint called "One Shot Sign Paint". It comes in half pints for about $15.00 US and is sold at auto paint stores for pin strippers. Easy and lays down nice and smooth with a brush too.
